I need to measure variable positive current/voltage and negative current/voltage through a single PIC. Measuring the high side is done. Measuring the negative side voltage is also done but I am stuck at the current monitoring for the negative voltage. Cannot use LT/Maxim opamps or current sensors due to unavailability. Tried referencing it with by modifying the classical high side current monitor. Failed. Using OP07. Any ideas ???
