How to set interrupt for Timer 0
Now have problem with time 0 set interrupt every 34 us
Here is my code ,that is correct or not
Trisb = %11111111
Trisa = %00000000
'DECLARE SYMBOLS
Symbol T0IF = INTCON.2 ' TMR0 Overflow Interrupt Flag
Symbol T0IE = INTCON.5 ' TMR0 Overflow Interrupt Enable
Symbol GIE = INTCON.7 ' Global Interrupt Enable
Symbol PS0 = OPTION_REG.0 ' Prescaler Rate Select
Symbol PS1 = OPTION_REG.1 ' Prescaler Rate Select
Symbol PS2 = OPTION_REG.2 ' Prescaler Rate Select
Symbol PSA = OPTION_REG.3 ' Prescaler Assignment
Symbol TOCS = OPTION_REG.5
'SET REGISTERS
'Below is the prescaler setting you chose....
PS0 = 0
PS1 = 0
PS2 = 0
PSA = 1
TOCS = 0 'set the clock source for internal oscillator
T0IF = 0 'clear the interrupt flag
T0IE = 1 'enable tmr0 interrupt
GIE = 1 'enable Global interrupts
'Below is the offset setting you chose....
TMR0 = 223
'START PROGRAM
On Interrupt goto Int
Strobe = 1 'strobe off
latch = 1 'lactch off
clock = 1 'CLOCK OFF ACTIVE HIGH
Sin3 = 0
Sin2 = 0
SIN1 = 0
Loop:
nap 7
goto loop
