12 Servo's together does not seem to work, Power problem
Hello All
Am currently making a robot with 4 legs and 3 servo's each leg,
am using the 16f877 to control it.
At the start I used the same power supply which I used with the Microcontroller but the servo started shifting positions if there was load on the legs,
Now I have a diffrent power supply for the servos, and ground is common, the shifting is stopped.
the problem is
1) with the same power source 5volts 500Ma if 2 servos are joint they move freely (use a push button to make it go clock wise and anti clockwise)
but the servo does not have enough power to get up.( have to lift it up manually and then it get is position)
2) if connected to 3or 4 servo then the other 2 does not have any power to even move.
question is that
1) do i need many power line to fulfill the power for 12 servo's ?
2) or do i need a transformer with more amps?
I have seen many hexapod designs with just one power supply and it controls 18 motors. and also the weight, how do they do that?
mac
Servo Motor Schematic clarification
Originally Posted by sayzer
Even if you use a stronger power supply, you may get the same problem along with some other problems.
Even though all V+ and GNDs will be parallel for all servos, the last ones in the power line will still be getting low voltage.
I suggest you make a connection as below.
In Figure1, S1 does not get the same voltage as S4 or S5.
In Figure2, all servos get the same voltage.
I am curious about the schematic diagram in figure 2, can u give possible PCB layout for those servos. including power supply, location & connection and a simple microcontroller like PIC16F84A? Do i have to design the pcb following the arrangement of servo connectors found in Figure 2?
I stopped the servo motor programming 'coz i also encountered the same problem. I have only 2 servos, one for steering and the other for acceleration. Both of them mounted perpendicular to each other. As I turn on the circuit, instead of performing the desired action which is move forward, the steering servo tends to turn left, sometimes, right. I still have to do some series of power on, then off, then on, then off until it behaves according to what is expected.
