Moving message on LED dot matrix
Dear friend Microcode used
Now we study moving message on LED dot matrix but did not work.
We have sample in code (CSS) but i not under stand on code need you help to conver c code to basic code.
Code:(CSS )
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,PUT,NOLVP
#use delay(CLOCK = 10000000 )
#use fast_io(B)
#bit STROBE = 0x06.0 //PIN_B0
#bit LATCH = 0x06.1 //PIN_B1
#bit CLOCK = 0x06.2 //PIN_B2
#bit SIN3 = 0x06.3 //PIN_B3
#bit SIN2 = 0x06.4 //PIN_B4
#bit SIN1 = 0x06.5 //PIN_B5
// | SIN2 | SIN3 |
// | Colum3 | Colum2 | Colum1 | Colum0 |
// |7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 | 7 6 5 4 3 2 1 0 ------
// | | | | 1 |
// | | | | 2 |
// | | | | 3 |
// | | | | 4 | ROW0
// | | | | 5 |
// | | | | 6 |
// | | | | 7 |
// |----------------|-----------------|-----------------|----------------------- SIN1
// | | | | 0 |
// | | | | 1 |
// | | | | 2 |
// | | | | 3 |
// | | | | 4 | ROW1
// | | | | 5 |
// | | | | 6 |
// | | | | 7 |
char const font[3][16] =
{0x00,0x00,0x00,0x00,0x00,0x7C,0x40,0x40,0x78,0x40 ,0x40,0x7C,0x00,0x00,0x00,0x00}, //E
{0x00,0x00,0x00,0x00,0x00,0x7C,0x10,0x10,0x10,0x10 ,0x10,0x10,0x00,0x00,0x00,0x00} //T
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,0x00,0x00,0x00,0x00,0x00,0x00} //Space
char const ScanRow1[16] =
0,0,0,0,0,0,0,0,1,2,4,8,16,32,64,128
char const ScanRow0[16] =
1,2,4,8,16,32,64,128,0,0,0,0,0,0,0,0
int buffer[4][16];
int Colum3,Colum2,Colum1,Colum0,Row1,Row0;
//int CheckClock,ValueBitSIN3,ValueBitSIN2,ValueBitSIN1;
int k,l,m,n,o,p,q;
void SendData16Bit();
void SendDataSIN8BitHighbyte();
void SendDataSIN8BitLowbyte();
void BeginData();
void ClearData();
#INT_TIMER1
void IntTimer1_isr()
STROBE = 1; //STROBE OFF
for (k=0;k<8;k++) // Row 0 to 7
Colum2 = buffer[2][k];
Colum0 = buffer[0][k];
Row0 = ScanRow0[k];
Colum3 = buffer[3][k];
Colum1 = buffer[1][k];
Row1 = ScanRow1[k];
LATCH = 0; //LATCH ON
LATCH = 1; //LATCH OFF
STROBE = 0; //STROBE ON
delay_us(50);
for (k=8;k<16;k++) // Row 8 to 15
Row0 = ScanRow0[k];
Row1 = ScanRow1[k];
delay_us(50);
//STROBE = 0; //STROBE ON
//set_timer1(65451); // FF AB interrupt 34uS
set_timer1(65400);
void main()
set_tris_b(0x00);
enable_interrupts(INT_TIMER1);
enable_interrupts(GLOBAL);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
CLOCK = 0; //Clock OFF Active High
SIN3 = 0; //S-IN3 OFF
SIN2 = 0; //S-IN3 OFF
SIN1 = 0; //S-IN3 OFF
ClearData();
BeginData();
//LOOP
while(1)
for(p=0;p<8;p++)
for (n=0;n<16;n++)
buffer[3][n] = ((buffer[3][n]) * 2) + (((buffer[2][n]) &0B10000000)/128) ; //colum3
for (n=0;n<16;n++)
buffer[2][n] = ((buffer[2][n]) * 2) + (((buffer[1][n]) &0B10000000)/128) ; //colum2
for (n=0;n<16;n++)
buffer[1][n] = ((buffer[1][n]) * 2) + (((buffer[0][n]) &0B10000000)/128) ; //colum1
for (n=0;n<16;n++)
buffer[0][n] = ((buffer[0][n]) * 2) + (((buffer[3][n]) &0B10000000)/128) ; //colum0
delay_us(100);
int i;
for(i=0;i<8;i++)
SIN3 = bit_test(Colum1,(i));
SIN2 = bit_test(Colum3,(i));
SIN1 = bit_test(Row1,(i));
CLOCK = 1; //Clock ON
int i;
for(i=0;i<8;i++)
SIN3 = bit_test(Colum0,(i));
SIN2 = bit_test(Colum2,(i));
SIN1 = bit_test(Row0,(i));
void BeginData()
for (n=0;n<16;n++)
buffer[0][n] = font[2][n]; // Space
for (n=0;n<16;n++)
buffer[1][n] = font[1][n]; // T
for (n=0;n<16;n++)
buffer[2][n] = font[1][n]; // T
for (n=0;n<16;n++)
buffer[3][n] = font[0][n]; // E
//for (n=0;n<16;n++)
// buffer[4][n] = font[2][n]; // Space
void ClearData()
for(l=0;l<4;l++) // clear buffer
for (m=0;m<16;m++)
buffer[l][m] =0;
If you come up with the circuit I may help
I have done a moving display with PBP but cannot share it due to commercial restrictions. If you are using Shift Registers then the idea is :
1. Get the font data from a lookup table
2. Dump column data for every row and light up that row, do it in even periods and you have got the scanning.
3. For moving message use a pointer in your message table and update it at regular intervals to scroll.
I know that this is very rudimentary. Post your schematic and I will try to help. I got the lookup table for the 5x7 matrix from this forum by dave and thankful for the same. So perhaps its my turn.
Re: Moving message on LED dot matrix
isaac, i'm using your code to drive 4x74hc595, but i can't find the things to change in the code.
i need to use 4 x 8x8 led matrix, but only work 2 of those.
i apreciate your help
