Interrupt Problem
Hello,
I use TMR1 to generate an interrupt.
All is working fine.
But when I call a procedure with GOSUB, e.g. GOSUB Pause1000, then the Interrupt doesn't work.
In this procedure is no interupt called, but when the program returns, the interrupt is working again.
So how can I make, that the interrupt works in procedures, too?
FrankM
I assume you are using PBP's "On Interrupt..." rather than your own Assembler Interrupt.
In this case the interrupt is not serviced until AFTER the current Basic command has finished executing... this means that if you have a ONE SECOND delay in the form of...
Pause 1000
then the interrupt will not occur until AFTER the Pause 1000 has completed. That means at worst-case there could be a 1 Second delay before you jump into your ISR.
How can you improve on this? Simply break your pause up into smaller segments...
For ByteCounter=1 to 100
Pause 10
Next ByteCounter
Here the overall timing is still 1 Second, but the interrupt will be serviced after 10mS worst-case instead. You can use Pause 1 instead for an even faster Interrupt Service, however, when you get down to 1mS instructions, and if timing is critical to you, the extra processing for your Counter Code will start having an impact to your timing... example...
For WordCounter=1 to 1000
Pause 1
Next WordCounter
...here you may find that you have not got exactly 1 Second, but 1.05 Seconds or thereabouts (the actual figure depends on many factors). Then instead of using Pause 1, use PauseUS instead, and adjust the value to compensate to get as close to your overall ideal 1 Second as possible... eg...
PauseUS 995
Next WordCounter
Melanie
Thanks for your answer, but that's not exactly my problem.
My Code looks like this:
ON INTERRUPT GOTO MyInt
GOTO Start
DISABLE
MyInt:
PIR1=0
'PINS
IF ReedPin=0 Then I2CTransfer
IF LadePin=0 THEN IsLoading
RESUME
ENABLE
Start:
T1CON=%00000101
INTCON=$C0
PIE1=%1
GOSUB SPKUp
PAUSE 100
GOTO ShutDown
SPKUp:
For SPKVAR1=10 to 60
FREQ=SPKVAR1*SPKVAR1
FREQOUT SpkPin, 10, FREQ
PAUSE 100
NEXT SPKVAR1
My Problem is:
If I call SPKUp, the Interrupt Handler won't work. So it doesn't check the ReedPin oder LadePin.
And now my question:
What can I make, that this works?
I used the PBP's Interrupt handler, because I can no Assembler ;)
FrankM
I disagree with you Frank... your posted code above CANNOT look like your code that doesn't work...
Your Subroutine MUST be positioned correctly...
(1) It must be located AFTER an ON INTERRUPT statement and...
(2) It must be located AFTER an ENABLE statement
I have tested all four examples below to double-check...
Example 1. This will Not work...
Jump to Start
Subroutine
ISR (Interrupt Service Routine with Disable/Enable)
Start:
On Interrupt Statement
Enable Statement
Main Program Loop
Example 2. This will not work
Jump to Start
Subroutine (with Enable)
ISR (with Disable/Enable)
Start:
Enable Statement
Main Program Loop
Example 3. This WILL work
Jump to Start
Start:
On Intterrupt Statement
Enable Statement
Main Program Loop
Subroutine
Example 4. This WILL work
Enable Statement
Jump to Start
Subroutine
Start:
Main Program Loop
Basically, the physical location of the Subroutine within your code MUST be AFTER the ON Interrupt Statement (which comes first) and after an ENABLE Statement (which comes second). Do not place the subroutine BEFORE an On Interrupt/Enable... it doesn't compile correctly.
Melanie
btw... forgot to say... Don't give up Music class... *smiles*
OK, I agree, it was my fault :D
The subs are in seperate files, which are included at the beginning of my main file.
So I'll have to include these files at the end of my main prgramm.
I'll try it later and see if it works, but I hope that this was the mistake and I think, that this was the mistake.
thanks
Frank
Thank you, it works!!!!
Frank
