2550 serout problems
I seem to have a problem moving from the f88 to the f2550.....
Code runs fine but seems to run faster than it should, I have a 16mhz crystal on it and a def osc 16 in my source.
Problem is my serout seems to be sending corrupt data, or at a guess, out of baud data, as what I get on screen is consistantly wrong.
any guesses anyone?
Also I just heard a rumour I can dump the crystal (cost cutting!) and use an 8mhz internal clock, if so can I still get low speed usb to copy the serial data to usb?
Guess? Sure, it's your config fuse setting dude!
Look at the faq, there's a whole thread that explain how to get and set them.
lol thanks, I didnt know I had to set the fuse in the programmer software by hand, it defaults to system PLL/3 and OSC HS/5.
I changed em to system (no divide) and osc /4
Does that mean its running at 4mhz?
I had hoped to get some more speed with it having a faster crystal on it.
The serout is working now.
I can go and hunt bigger issues in the code....
