Hi all,
i used 18f452 and ( 10 mhz x 4 hs_pll ) 40 mhz osc. and i want to datas from pc( vb 6.0) to pic ( picbasic pro 2.46 ) . and it ll write to 24c64 eeprom. pls can you send me sample code or complete sample program code..
thanx now...
Hi all,
thanx now...
AndCode:ControlByte con %10100000
Addr var word
ByteA var Byte
Addr=0
I2CREAD SDA,SCL,ControlByte,Addr,[ByteA]
Hserout [ByteA]
http://rentron.com/VisualBasic.htm
and have a look to this miniterminal i did awhile back
http://www.picbasic.co.uk/forum/atta...3&d=1117969258
Ok it's not what you want... but it may help.
http://www.yes-tele.com/mscomm.html
i ll look these sites... thanx.....
and can i have a problem... lookup command...
q var byte
w war byte
lookup q,[$7f,$01,$01,$01,$00,$3f,$48,$48,$48,$3f,$00],W
lookup index is byte but i want to use word. is it possible.
How about LOOKUP2?
