Any idea's on porting this to PBP?
I copied this from scott edwards, all the code is his, i just modified it a little to try it out with PBP, all i get is a blank LCD. my version gets rid of the nibble variable, which is where i think it might go wrong, if someone could get this to work it would benifit everyone im sure. im using a 4X20 LCD, i've used a different aproach to large letters that worked fine but ate up most of my 16F648A's resorces (for a compass heading display).
ALL PROPS TO SCOTT EDWARDS AND SEETRON!!!
CMCON = 7 ' Turn off un-needed PIC hardware
VRCON = 0 ' '' ''
CCP1CON = 0 ' '' ''
INTCON = %00000000 ' '' ''
I con $FE ' Instruction prefix.
ClrLCD con 1 ' Clear-LCD instruction.
cgRAM con $40 ' Address 0 of CG RAM.
EEptr var word ' Pointer into EEPROM.
pat var EEptr ' Alias for EEptr.
dispVal var word ' Value to be displayed as big digits.
temp var byte ' Temporary byte variable.
decade var word
nbl var byte ' Index into number-pattern tables. changed.was a NIBBLE
digit var byte ' Current digit to display
line var byte ' LCD line
' ====This section may be omitted with newer (post July 96)
' ====4x20 Serial LCD modules. Cut from here...============== >>>
bitPat0 DATA 0,0,0,1,3,7,15,31 ' Left-right up-ramp shap
bitPat1 DATA 0,0,0,16,24,28,30,31 ' Right-left " "
bitPat2 DATA 31,15,7,3,1,0,0,0 ' Left-right down ramp.
bitPat3 DATA 31,30,28,24,16,0,0,0 ' Right-left " "
bitPat4 DATA 0,0,0,0,31,31,31,31 ' Lower block.
bitPat5 DATA 31,31,31,31,0,0,0,0 ' Upper block.
bitPat6 DATA 31,31,31,31,31,31,31,31 ' Full block.
bitPat7 DATA 0,0,0,0,0,0,0,0 ' Full blank
' <<<...to here. ===============================================
low 0 ' Make the serial output low
pause 1000 ' Let the LCD wake up.
' ====4x20 Serial LCD modules. Cut from here...============= >>>
LCDOUT I,cgRAM ' Enter CG RAM.
for EEptr = 0 to 63 ' Write the bit patterns
Read EEptr,temp ' to the LCD.
LCDout temp
next
LCDOUT I,ClrLCD ' Clear the LCD.
pause 1
' Demo Loop: Show dispVal in Big Numerals, Increment, Loop
again:
gosub bigLCD
dispVal = dispVal + 1
goto again:
' Subroutine Displaying Large Numbers
bigLCD:
for line = 0 to 3
decade = 1000
lookup line,[$80,$C0,$94,$D4],temp
LCDOUT I,temp
for digit = 3 to 0
nbl = dispVal dig digit
gosub getPattern:
if dispVal = 0 and digit = 0 then skip0:
if dispVal < decade then blankIt:
skip0:
LCDOUT pat.bIT15,pat.bit14,pat.bit13,pat.bit12,pat.bit11,pat.bit10,pat.bit9,pat.bit8,pat.bit7,pat.bit6,pat.bit5,pat.bit4,pat.bit3,pat.bit2,pat.bit1,pat.bit0 ' was NIBS!
goto cont:
blankIt:
LCDOUT " "
cont:
if digit = 0 then skip1:
LCDOUT 32
skip1:
decade = decade/10
next
next
' Subroutines Defining Big-Character Patterns
getPattern:
branch line,[first,second,third,fourth]
' 0 1 2 3 4 5 6 7 8 9
first:
lookup nbl,[$0551,$7067,$0551,$0551,$6776,$6555,$0557,$2556,$0551,$0551],pat
second:
lookup nbl,[$6776,$7767,$7743,$7743,$6776,$2441,$6041,$7703,$2443,$6776],pat
third:
lookup nbl,[$6776,$7767,$0577,$7751,$2556,$7776,$6776,$7767,$0551,$2536],pat
fourth:
lookup nbl,[$2443,$7464,$6444,$2443,$7776,$2443,$2443,$7767,$2443,$7443],pat
