Please explain about this program
I need someone to help me explain about this program and tell me if there is error occur. I will attached the circuit altogether if someone know about the circuit error if any.I am new in picbasic and electronic,I beg all expert out there, please help me......!
' PicBasic Pro program
' 10-bit A/D conversion
' Balancing robot using Sharp GP2D12
' Use a 16f876 pic mcu from microchip
define osc 20
' Define ADCIN parameters
Define ADC_BITS 10 ' Set number of bits in result was 10
Define ADC_SAMPLEUS 50 ' Set sampling time in uS was 50
define DEBUG_REG PORTB
define DEBUG_BIT 5
define DEBUG_BAUD 9600
define DEBUG_MODE 1
define DEBUG_PACING 500
tiltfor var word ' ET Sensor Forward
tiltbac var word ' ET sensor Back
lwheel var word ' Left wheel zero speed
rwheel var word ' Right wheel zero speed
speed var word ' speed variable
k con 7 ' k factor
smax con 500 ' speed limiter
ADCON1 = %10000010 ' Set PORTA analog and right justify result
'lwheel=747 'zero calibrate left wheel
'rwheel=747 'zero calibrate right wheel
speed=0
start:
debug "Balbot ET"
high portc.2
low portc.2
adcin 1, lwheel 'read trimmer for left wheel zero speed
adcin 2, rwheel 'read trimmer for right wheel zero speed
loop:
adcin 0, tiltfor ' Read channel 0 to adval
adcin 4, tiltbac
speed = abs (tiltfor - tiltbac)* k
if speed > smax then speed = smax
if tiltbac > tiltfor then back
forward:
low portc.0
pulsout portc.0,(lwheel + speed) 'left wheel
pause 5
low portc.1
pulsout portc.1,(rwheel - speed) 'right wheel
pause 5
goto loop
back:
low portc.0
pulsout portc.0,(lwheel - speed) 'left wheel
pause 5
low portc.1
pulsout portc.1,(rwheel + speed) 'right wheel
pause 5
goto loop
