Hi Guys,
I'm having a strange problem with EpicWin/MeProg and my parallel port programmer.
First, I tried to program a 16F876 to check that everything was fine, and the blinking code for this pic worked ok. Did the same with a 16F84 and worked too. So, the everything seems to be ok so far.
Then, I modified the blinking code for the 16F767 and tried to program it but I got the 0000 error, or the 000E error. I read everything on this forum but nothing helped.
When I was trying a few more things this problem appeared. Steps:
1) erased the pic
2) read the code inside the pic (all 3FFF, blank)
3) programmed the pic with this code (all 3FFF, blank)
4) everything went fine.
But, if I try to program my blinking code I get that strange error.
Is the pic bad? Why can I program all 3FFF but not my blinking code? :(
Thank you very much.
Daniel.
