I'm trying to set a variable to the negative of another variable by saying:
remaining = -rows
Where rows has already been set to 8, but remaining seems to end up being set to 0 instead of -8.
remaining = -rows
"...Keep in mind that all of the math and comparisons in PBP are unsigned."
Will you use that negative number in a math operation or is it just for a representation on LCD or sending via a serial comm. etc?
Unless it has something to do with a previous version of PBP, can't say.
But this simple program comes up with 248 (-8). PBP 2.46Something you might try is ...Code:@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
define OSC 20
clear
remaining var byte
rows var byte
rows = 8
remaining = -rows
stop
remaining = 0 - rows
I'm not using it for any math operations, just to control the start of a for loop.
for some reason when remaining is negative this part "crashes"Code:for i = remaining toremaining + (rows - 1)
if i < 0 then
messageScroll[writePos] = $0
if i >= 0 and i < messagelength then
messageScroll[writePos] = message[i]
if i >= messageLength then
messageScroll[writepos] = $0
writePos = writePos + 1
next i
Hi RUBiksCUbe,
Where do you get this "Remaining" variable into negative? Are you setting it to "negative" somewhere before this loop as you stated in the example above?
Also, here I made the same code of yours in a different look.
It seems you only need the negative value for " messageScroll[writePos] = $0 "
for i = remaining to remaining + (rows - 1)
if i < 0 then
if i < messagelength then
next i
Also, are you setting other variables to an initial value at the beginning?
At the very beginning I have
Code:rows = 8
remaining = (0 - rows)
Couple problems here.
As Sayzer pointed out ... "...Keep in mind that all of the math and comparisons in PBP are unsigned."
This means that
if i < 0 then
will always evaluate to FALSE. And the FOR loop will always terminate before executing anything because -8 is really 248 in PBP math (assuming byte vars).
You'll need to find positive numbers to work with.
Or testing the MSB of the variable. If 1=> negative if 0=>positive.
I make load indicator with loadcell, i using pic 16f877. For 16 bit adc i using cd4066 , value from -65535 to +65535 with peak hold
I setup - reading
B0 var word ( reading of adc )
B1 var word
B2 var byte
main: if B0 > 0 then ( B1 = B0 ) and ( B2 = 43 ) ' 43 is + sign
if B0 < 0 then B1 = ( 65535 - B0 ) and ( B2 = 45 ) '45 is - sign
lcdout $fe,1
lcdout " Load ", B2, dec5 B1
Originally Posted by precision
Hi precision,
Your IF statements are not precise :)
You should correct them as follows.
Code:if B0 > 0 then
B1 = B0
B2 = 43
if B0 < 0 then
B1 = 65535 - B0
B2 = 45
B0 never equals to zero?
This is actually the idea of assigning a flag that will indicate negative status.
That is why I asked above, will you use this negative number in a math operation.
You can have a flag, like NegFlag=1 meaning you have the negative value, and NegFlag=0 meaning positive value.
If of course it can be useful in your case.
