Alguien que me ayude por favor...
I use PBP recently, I generally used assembler or HT-Pic, I have two problems mainly:
1. - the LCD doesn't initialize correctly at the beginning of the program, I have to hope the program restarts and after that the second line appears
2. - the communication with the memory doesn't work, this communication doesn't write neither reads anything, the pin number 7 is connect to ground and the pins 1 2 and 3 they are also to ground, I have resistances to VCC in SDA and SCL 1K and I have try with resistance from 10 to 50K.
The crystal that I use is of 20MHz
the pic is the 16f877
SCL=PORTC,3
SDA=PORTC,4
the memory is 24LC08B
the program is this:
Define LCD_DREG PORTD 'puerto de comunicacion con el lcd
Define LCD_DBIT 0 'inicio en el bit 0 del puerto D
Define LCD_RSREG PORTD 'puerto de control RS
Define LCD_RSBIT 5 'bit RS
Define LCD_EREG PORTD 'puerto de control E
Define LCD_EBIT 7 'bit E
Define LCD_RWREG PORTD 'puerto de control RW
Define LCD_RWBIT 6 'bit RW
Define LCD_BITS 4 'bits de datos
define LCD_LINES 2 'lineas en el LCD
define I2C_SLOW 1 'i2c para cristal rápido
define OSC 20 'velocidad del cristal
scl var PORTC.3
sda var PORTC.4
dato var byte 'dato a escribir
dire var byte 'dirección del dato
dato=250
Pause 500 ' espero que el lcd inicie
lcdout $fe,1 'limpia el LCD
lcdout $fe,$0c 'no tengo idea que hace
for dire=0 to 10
i2cwrite sda,scl,$a0,dire,dato 'escribe el dato en el LCD en la direccion dire
dato=dato-1
lcdout "escribe"
lcdout $fe,$c0
lcdout #dire,":",#dato
next dire
for dire=0 to 10
lcdout $fe,1
lcdout "lee"
lcdout $fe,$c0
dato=0
next dire
help me please
ayudame gebuuuuuuus que estoy que me mato con este programa puerco...
ATT: Payatronico
