Effects of Current Draw Using Internal VS External PullUps
I am currently writing a little bot of simple code for a 10F206 Six Pin ver.
I have been studying the DICE routine written and posted by Ms. Melanie Newman.
The program just pulses out random high/low logic to a mosfet.
By setting TRISIO=%11111111
CMCONO=%00000001
Option_REG.5=0
Status_REG=10010000 ' the GPWU and GPPU for pullups.
I noticed that when I was in a closed loop waiting for GPIO.1 to go Low (via switch) that the uA current was about 40 to 60 uA without out and external 10k pullup resistor.
I did not have a Pullup resistor on GPIO.3 (MCLR) either.
I powered down the chip and added pullups to GPIO.1 and GPIO.3 .
The Current now while in the loop looking for a low on GPIO.1 is now 8 to 10.4 uA.
The circuit is on a breadboard and should be away enough from RF.
The circuit does not work reliable if the external pullups (10k) are removed and only using the Weak Pullups.
Any one got a hint were to read more on this.
I am using Pic Basic Pro ver 2.47
Rix
