PIC 16F877A Keypad interfaceded with Input and LCD as Displays Output
I am new to PIC programming,, have been fiddling with BLINK.Bas
and managed to make the LCD show a message "LED Blinking"
just before the LED blinks.
I am using the MCS PICBasic Pro for the sake of compiling and am using the
DIY K149 Pic Micro Programmer to program my PIC16F877A.
Now I was wondering how would I be able to use the Keypad as an input
and display things on the LCD.
I am sure my question is very newbie, but if someone could explain me
how I could manage my inputs and storing into registers and then output
it to whatever port pin etc., then it would be of great help.
Thank you!
The LCD To Keypad Routine I compiled
Hardware Connections:
I connected the Keypad to the Port B (0-7) not sure about which pins were
rows and which were colums but I changed connections to take care of both
cases.
Now the LCD reaches "TESTING Keypad" and then nothing happens
when I press a Key upon the dispay message " Press Key Now"
I am wondering if theres anything wrong in the Keypad routine..
Any help would be greatly appreciated.. since the next step of my
project depends greatly on getting this working and understand
whats happening..in this code
Thank you
The .BAS Code
Define LOADER_USED 1
Define OSC 4
'Define LCD registers and bits
DEFINE LCD_DREG PORTC 'Define PIC port used for LCD Data lines
DEFINE LCD_DBIT 0 'LCD Data Starting Bit = Bit 0 or 4
DEFINE LCD_EREG PORTE 'Define PIC port used for E line of LCD
DEFINE LCD_EBIT 2 'Define Port pin used for E connection
'DEFINE LCD_RWREG PORTD 'Define PIC port used for RW line of LCD
'DEFINE LCD_RWBIT 0 'Define Port pin used for RW connection
DEFINE LCD_RSREG PORTD 'Define PIC port used for RS line of LCD
DEFINE LCD_RSBIT 1 'Define Port pin used for RS connection
DEFINE LCD_BITS 4 'Define the 4 bit communication mode to LCD
DEFINE LCD_LINES 4 'Define using a 4 line LCD
DEFINE LCD_COMMANDUS 2000 'Define delay time between sending LCD commands
DEFINE LCD_DATAUS 50 'Define delay time between data sent.
DEFINE KEYPAD_ROW 4 ' 4 ROW keypad
DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB
DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4
DEFINE KEYPAD_COL 4 ' 4 COL keypad
DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB
DEFINE KEYPAD_COL_BIT 0 ' COL0 = PORTB.0
DEFINE KEYPAD_DEBOUNCEMS 200 ' debounce delay = 200 mSec
DEFINE KEYPAD_AUTOREPEAT 1 ' use auto-repeat feature
'*********Port Assignments*************************************** **********************************************
LED var PortB.2 ' Variable so we don't have to remember what port and bit it is on
' -----[ Initialize Hardware ]------------------------------------------------
TRISA = %00001111 ' Set PORTA to all input (Thermistor is on A.1)
ADCON1 = %10000100 ' Set PORTA analog and right justify result
TRISB = %00000000 ' PortB are all outputs
PORTB = %00000000 '
TRISC = %10010000 '
PORTC = %00000000 '
TRISD = %00000000 ' LCD
PortD = %00000000 '
TrisE.0 = 1
TrisE.1 = 0
PortE.1 = 0
TrisE.2 = 0
PortE.2 = 0
'Program Definitions
col Var Byte ' Keypad column
row Var Byte ' Keypad row
key Var Byte ' Key value
OPTION_REG.7 = 0 ' Enable PORTB pullups
ADCON1 = 7 ' Make PORTA and PORTE digital
'Low PORTE.2 ' LCD R/W low (write)
Pause 1000
LCDOut $FE,1,"TESTING",$FE,$C0,"KEYPAD DISPLAY"
Pause 2000
LCDOut $FE,1,"CLICK ANY KEY",$FE,$C0,"NOW..."
loop: Gosub getkey ' Get a key from the keypad
Lcdout $fe, 1, #key ' Display ASCII key number
Goto loop ' Do it forever
' SubRoutines placed after the END statement
' Subroutine to get a key from keypad
getkey:
Pause 50 ' Debounce
getkeyu:
' Wait for all keys up
PORTB = 0 ' All output pins low
TRISB = $f0 ' Bottom 4 pins out, top 4 pins in
If ((PORTB >> 4) != $f) Then getkeyu ' If any keys down, loop
Pause 50 ' Debounce
getkeyp:
' Wait for keypress
For col = 0 To 3 ' 4 columns in keypad
TRISB = (dcd col) ^ $ff ' Set one column pin to output
row = PORTB >> 4 ' Read row
If row != $f Then gotkey ' If any keydown, exit
Next col
Goto getkeyp ' No keys down, go look again
gotkey: ' Change row and column to key number 1 - 16
key = (col * 4) + (ncd (row ^ $f))
Return ' Subroutine over
' Subroutine over
