recognizing a serin2 string
Hello all.
I am new to pics and pic basic. I have a project where I would like to detect two different strings of data coming into a serial line. There will be a constant stream of data presented to the line, but I want to set an output port bit on when one sequence of letters/numbers is found and then reset that port bit when another sequence is found. Here are some details.
1. incoming serial parameters, 8 bits, 1 stop, 45.45 baud
2. listen to incoming data, set a bit high when "KC2NWG" is found in the stream
3. listen to incoming data, set a bit low when "NNNN" is found in the stream.
4. loop back to 2
Thats it!
In reality it will be a 5 bit byte coming in but I thought this example would be easiest to understand.
Anyone help with this? I suspect I want to use the WAITSTR for SERIN2 function, but not sure how.
thank you
Eugene
