How would you go about using an xor function with 2 outputs, without using discrete logic IC followers, is this DOable in code? What I am seeking to do is combine 2 outputs as follows: output 1 logic hi or low depending on what it needs to output. output 2 would be a cycling hi/low signal. the output would either cycle opposite output 2 or output 1 in a steady state depending upon what output 2 is doing. I can do this using a 7486 xor gate, I would rather do it in code but have Zero Idea as to how.
Thanks Again
JS
RTFM / CONFUSED = DUMMY W / HEADACHE
