Hello
This question is regarding the A/D on a 16F877A....
I want to set up VREF to be 10VDC and i am powering the pic with 5VDC...
Is it going to be a problem that VDD=5VDC and the VREF=10VDC?
Just curious
Hello
Just curious
Per the datasheet, Section 17.0, the maximum voltage on RA3 is VDD+0.3V. In your case that would be 5.0+0.3=5.3V. 10V will most likely damage the PIC - do not do that. If your analog signal is larger than 5.0 V, consider using a voltage divider to reduce the analog signal. Please reply if you need more input.
That would have really sucked!!!
Back to the drawing board I guess....
Thanks for stopping me from making a huge mistake!
R
