Hi!
I'm using PIC BASIC with a PIC18F4680. I'm wondering whether there's anyone who could tell me how to connect MCP9800 to the PIC and get the PIC to display the temperatue on a serial or LCD.
Thanks!
Ernesto
Hi!
Thanks!
Ernesto
MCP9800 connection? =>PBP I2CWRITE section
Serial lcd: HSEROUT, SEROUT, SEROUT2, DEBUG
Hi!
This is my first solution.
'* Name : MCP9803.BAS *
'* Author : Ernesto *
'* Notice : test MCP9803 with pic18f2680 *
'* Date : 30/07/2006 *
'* Version : 1.0 *
'* Notes : *
define LOADER_USED 1 ' utilisation du Bootloader Tinybld 1.91
define OSC 40 ' Quartz à 10MHz * 4
DEFINE HSER_BAUD 19200 ' set baud rate to 19200
FLOAT VAR WORD '
SDA var PORTC.4
SCL var PORTC.3
T_MSB var byte 'Température MSB Signe + 7 Bit
T_LSB var byte 'Temperature lsb decimal
;MCP9800 DATASHEET
adr_R con %10010001 ;adr mpc9803 read
adr_W CON %10010000 ;adr mpc9803 write
MCP9800_TEMPERATURE CON 0 ; Register pointer
MCP9800_CONFIGURATION CON 1
MCP9800_HYSTERESIS CON 2
MCP9800_LIMITSET CON 3
ONESHOT_OFF CON %00000000 ;bit for register configuration
ONESHOT_ON CON %10000000
RESOLUTION_9bit CON %00000000
RESOLUTION_10bit CON %00100000
RESOLUTION_11bit CON %01000000
RESOLUTION_12bit CON %01100000
FAULT_QUEUE_0 CON %00000000
FAULT_QUEUE_2 CON %00001000
FAULT_QUEUE_4 CON %00010000
FAULT_QUEUE_6 CON %00011000
ALERT_ACTIVE_LOW CON %00000000
ALERT_ACTIVE_HIGH CON %00000100
COMP_MODE CON %00000000
INT_MODE CON %00000010
SHUTDOWN_OFF CON %00000000
SHUTDOWN_ON CON %00000001
MCP9800_CONFIG con oneshot_off | Resolution_11bit |Fault_queue_0 | ALERT_active_low | Comp_mode | shutdown_off
debut:
hserout [$D,$A]
hserout ["************************************************* ",$D,$A]
hserout ["* Test du capteur de température MCP9803 *",$D,$A]
hserout [$D,$A]
init_MCP9800:
i2cwrite SDA,SCL,adr_W,[mcp9800_configuration,mcp9800_config]
i2cwrite SDA,SCL,adr_W,[mcp9800_temperature]
loop:
i2cread SDA,SCL,adr_R,[T_msb,T_lsb]
;float = (T_lsb >>7 ) * 5 ; resolution 9 bit
;float = (T_lsb >>6 ) * 25 ; resolution 10 bit
float = (T_lsb >>5 ) * 125 ; resolution 11 bit
hserout ["T_msb=",BIN8 T_msb," T_lsb=",BIN8 T_lsb, " Température =",SDEC T_msb,",",dec float,"C" ,$D,$A]
pause 200
goto loop
Not bad, I tried this one and it worked, had problems with the LCD grounding but the code was good, this code is also suitable for many other temp sensors.
It's possible to pull the i2c bus and put the mcp9803 temp sensor far away from controller ?(Around 2 meters by using shielded cable)
Thanks.
Hello *
I connect MCP9801 to the PIC and i put the 3 Adressline to VCC (A0,A1,A2)
So i change onliy the 2 Lines of the Programm above:
adr_R con %10011111 ;adr mpc9803 read Adresse 111
adr_W CON %10011110 ;adr mpc9803 write Adresse 111
I get always 16.0 C on the display.
Thank for feedback.
Rolf
