Hi there,
Does anyone out there have PIC BASIC code to interface a PIC (I'm using the PIC16F877) to a PCF8583 real time clock IC?
Thanks!
Maria.
Hi there,
Thanks!
Maria.
Anyone can help me ?
I'm looking for 8583 routines to read and write data in i2c.
How can i increase minutes and then rewrite to 8583 ?
Thanks to all.....
The pins: sda and scl as inputs or outputs to microcontoller?
If As outputs:
sda=1 'high the portx.y, x is the port of micr.,y is the bit of portx.
scl=1 'high the same as previous
DECLARE HBUS_BITRATE 100 ' and other values
TRISC=%00000000 'as outputs
after you try with:hbstart,hbusout,hbstop (in pic basic functions)
if you have other problem you ask me.
regards
this will never work with Melabs. In case it's working... you should have a look on that forum ;)Quote:
Hi Maria, Lupuccio and PCF8583 users.
' Ime programa: RTC.BAS
' Opis: program ilustruje primenu sata realnog vremena PCF8583.
' Za povezivanje sa mikrokontrolerom se koristi I2CREAD
' naredba.
DEFINE LCD_DREG PORTD ' I/O port na kome se nalazi LCD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 2 ' Register select pin
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 3 ' Enable pin
DEFINE LCD_BITS 4 ' 4-bitni data bus
DEFINE LCD_LINES 2 ' LCD ima dva reda karaktera
symbol SCL = PORTC.3 ' I2C data pin
symbol SDA = PORTC.5 ' I2C clock pin
Sec var bit
B0 var byte
S var byte ' Sekunde
M var byte ' Minuti
H var byte ' Sati
D var byte ' Dan
Mn var byte ' Mesec
Y var byte ' Godina
OPTION_REG = $7f ' Omoguci PORTB pullup otpornike
lcdout $fe,1 ' Obrisi ekran displeja
I2CREAD SDA,SCL,%10100001,2,[S]
I2CREAD SDA,SCL,%10100001,3,[M]
I2CREAD SDA,SCL,%10100001,4,[H]
I2CREAD SDA,SCL,%10100001,5,[D]
I2CREAD SDA,SCL,%10100001,6,[Mn]
I2CREAD SDA,SCL,%10100001,6,[Y]
lcdout $fe,1 ' Obrisi displej
lcdout $fe,2 ' Prvi red prvi karakter
lcdout "Time: ", hex(H),":", hex(M)," ", hex(S)
lcdout $fe,$c0 ' Drugi red, prvi karakter
lcdout "Date: ", hex(D),".", hex(Mn),".20",hex(Y)
Pause 500
goto Main ' Ponovi sve
End ' Kraj programa
Thanks to all for the answers.....
The only problem that i have... ( a big problem ) is set hour and minutes with buttons.
Unfortunely i haven't the code here.
Next week i will post my code.
and then i hope that someone can help me.
Thanks again to all.
That's not a problem... learning opportunuities.
USE I2CWRITE with the same settings as I2CREAD should work
you just need to test your pushbbuton...
but certainely better if you use something likeCode:lcdout $fe,1 ' Obrisi displej
'<== Here
Pause 500
yeah just an idea. not everything on a plate and you'll have to do some homework around the above.Code:lcdout $fe,1 ' Obrisi displej
While Delay<5000 ' Delay loop of 500 mSec
' Select case pushbutton and set/hour time here+I2CWRITE
' if there's no push button pressed Do a PAUSEUS 100 and increment
' Delay Variable.
Wend
The PCF8583 is very similar to DS1307.
Melanie has written an excellent example for the DS1307.
click here for MN1307.txt
It should work on the PCF8583 with very small modifications.
part is mine and part i' have found on the net.
with my circuit it works
Thanks to all.
device = 16f876A
xtal = 4
CONFIG XT_OSC , WDT_OFF , PWRTE_ON , BODEN_OFF , LVP_OFF , CP_OFF , DEBUG_OFF
LCD_DTPIN portb.4 ' dati lcd
LCD_RSPIN portb.1 ' register select
LCD_ENPIN portb.3 ' enable lcd 1
LCD_INTERFACE 4 ' interfaccia lcd 4 bit
LCD_LINES 2 ' linee lcd
DECLARE SDA_PIN PORTC.4
DECLARE SCL_PIN PORTC.3
'*** variabili ************************************************** ***************
delayms 200 'stabilizza LCD
cls
dim bcd_to_bin 'variable used in BCD and Binary conversion routines
dim low_bits 'low byte for Binary to BCD routine
dim high_bits 'high byte for Binary to BCD routine
dim pcf8583_address 'pcf8583 internal registers address(2=seconds,3=minutes etc.)
Dim second as byte
Dim minute as byte
Dim hour as byte
dim setup as byte
symbol clkout=%10100000 'set the 8583 to receive data
symbol clkin=%10100001 'set the 8583 to transmit data
Symbol button1 = portc.0
Symbol button2 = portc.1
Symbol button3 = portc.2
pcf8583_address = 0
setup = 0
second = 0
minute = 0
hour = 0
cls
delayms 200
' qui inizia il programma che legge dal 8583
C_upd:
'*** Visualizzazione ora ************************************************** *****
busin %10100001,2,[second,minute,hour]
pcf8583_address = 2:gosub read_time 'read seconds data from 8583
second=bcd_to_bin 'convert to binary
pcf8583_address = 3:gosub read_time 'read minute data from 8583
minute=bcd_to_bin 'convert to binary
pcf8583_address = 4:gosub read_time 'read hour data from 8583
hour=bcd_to_bin 'convert to binary
print at 1,5, dec2 hour,":",dec2 minute,":",dec2 second
'*** menu start
if button1 = 0 then inc setup
if setup = 1 then goto set_min
if setup = 2 then goto set_hour
if setup > 2 then
print at 2,1," "
setup = 0
goto C_upd
set_min:
print at 2,5,"Set Min "
if button2 =0 then
busin clkin,3,[bcd_to_bin] 'leggi i minuti
gosub conv_to_bin ' li converte in binario
inc bcd_to_bin
if bcd_to_bin > 59 then bcd_to_bin = 0
delayms 100
gosub convert_to_bcd
busout clkout,3,[bcd_to_bin]
delayms 10
goto c_upd
set_hour:
print at 2,5,"Set Hour"
if button2 =0 then
busin clkin,4,[bcd_to_bin] 'leggi le ore
inc bcd_to_bin
if bcd_to_bin > 23 then bcd_to_bin = 0
delayms 100
busout clkout,4,[bcd_to_bin]
delayms 10
goto c_upd
'*** antirimbalzo ************************************************** ************
'Debounce: DELAYMS 200
' Update=1
' goto c_upd
' legge il dato dall'indirizzo puntato da "pcf8583_address"
' il dato viene memorizzato nella variabile "bcd_to_bin"
read_time:
busin clkin,pcf8583_address,[bcd_to_bin]
gosub conv_to_bin
' Questa routine converte il byte da binario a decimale e lo carica nella
' variabile "bcd_to_bin" e lo ritorna nella stessa variabile "bcd_to_bin"
' Se il valore è "9" o meno, non fa nulla perche in BCD o BIN sono uguali.
conv_to_bin:
select bcd_to_bin
case 16 to 25
bcd_to_bin=bcd_to_bin-6
case 32 to 41
bcd_to_bin=bcd_to_bin-12
case 48 to 57
bcd_to_bin=bcd_to_bin-18
case 64 to 73
bcd_to_bin=bcd_to_bin-24
case 80 to 89
bcd_to_bin=bcd_to_bin-30
case 96 to 105
bcd_to_bin=bcd_to_bin-36
case 112 to 121
bcd_to_bin=bcd_to_bin-42
case 128 to 137
bcd_to_bin=bcd_to_bin-48
case 144 to 153
bcd_to_bin=bcd_to_bin-54
endselect
' Conversione da binario a BCD
' Il byte convertito viene caricato nella variabile bcd_to_bin
' e viene restituito nella stessa variabile bcd_to_bin
convert_to_bcd:
low_bits=bcd_to_bin//10 'get lsb,same for Bin and BCD
high_bits=bcd_to_bin/10 'get msb
bcd_to_bin=high_bits*16 'convert msb to BCD
bcd_to_bin=bcd_to_bin+low_bits 'add BCD msb and lsb together
Dear friends, Maria and all:
My name's Francisco Fambrini and
I am a Brazilian Electronic Engineer and my website is www.fdai.net
I would like to help my friends that have problems with PCF8583 and Melabs PICBasicPRO
My code for this :
' PCF 8583 APREDENDO_1.0
' programa para testar o chip PCF8583
' na placa do Distribuidor de Energia
' 26/Fev/2006
define OSC 20
DEFINE ADC_BITS 10
define ADC_CLOCK 1
DEFINE LCD_DBIT 4
DEFINE LCD_RSBIT 2
DEFINE LCD_EBIT 3
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
symbol SCL = PORTC.3 ' I2C clock
symbol SDA = PORTC.5 ' I2C data
symbol UP = PORTA.4
SYMBOL DOWN = PORTA.3
SYMBOL ENTER = PORTA.2
SYMBOL SEL = PORTA.1
; Configuração do PIC
TRISA=%00111111
TRISB=%00000000
TRISC=%00100000
TRISD=%00000000
ADCON1 = $0E 'Configura somente RA0 como entrada de AD
PORTB=%00000000
PORTC=%00000000
PORTD=%00000000
' VARIAVEIS DO PROGRAMA
HOUR VAR BYTE
MINUTE VAR BYTE
DAY VAR BYTE
MONTHY VAR BYTE
YEAR VAR BYTE
S VAR BYTE
M VAR BYTE
H VAR BYTE
D var byte
Mn var byte
Y var byte
TEMPO VAR WORD
lcdout $fe,1 'limpa o display
Pause 500
lcdout "PCF8583 Aprender"
Lcdout $fe,$c0
LCDOUT "FDAI Eletronica"
Pause 1500
Pause 100
I2CREAD SDA,SCL,%10100001,7,[Y]
IF PORTA.1=0 THEN GOSUB ACERTAR
lcdout $fe,1 'Limpa o LCD
lcdout $fe,2 'cursor n primeira posição
lcdout "Hora: ", hex(H),":", hex2(M),":", hex2(S)
lcdout $fe,$c0 'segunda linha do display
lcdout "Data: ", hex2(D),".", hex2(Mn),".20",hex2(Y)
Pause 500
goto Main 'VOLTA PARA O LOOP PRINCIPAL
' Rotina de ajuste do relogio RTC
ACERTAR:
lcdout $fe,1
Lcdout "Acertar hora"
Pause 1000
TEMPO = 1000
'Verifica se algum botao de ajuste foi pressionado:
VER_BOTOES:
IF TEMPO =0 THEN
GOSUB GRAVAR_HORARIO
tempo = tempo -1
' Checa se algum botao de ajuste de h/min foi pressionado
If PORTA.3 = 0 Then decmin
If PORTA.4 = 0 Then incmin ' Last 2 buttons set minute
If PORTA.1 = 0 Then dechr
If PORTA.2 = 0 Then inchr ' First 2 buttons set hour
pause 50
Goto VER_BOTOES
' Increment minutes
incmin: minute = minute + 1
If minute >= 60 Then
minute = 0
Endif
Goto debounce
' Increment hours
inchr: hour = hour + 1
If hour >= 24 Then
hour = 0
Endif
Goto debounce
' Decrement minutes
decmin: minute = minute - 1
minute = 59
Endif
Goto debounce
' Decrement hours
dechr: hour = hour - 1
If hour >= 24 Then
hour = 23
Endif
goto debounce
'essa é uma parte da rotina de acerto do relogio
debounce: 'atualiza o relogio na tela na hora do acerto do relogio
pause 200
tempo= 90
lcdout $fe,1
Lcdout $fe,2
Lcdout "Acerte Horario:"
lcdout $fe,$c0
Lcdout dec2 hour, ":", dec2 minute, ":00"
goto VER_BOTOES
GRAVAR_HORARIO:
'Converte para Hexadecimal
DAY = 26
MONTHY = 4
YEAR=06
M = MINUTE/10*16 + MINUTE//10
H= hour/10*16 + hour//10
D= DAY/10*16 + DAY//10
Mn= MONTHY/10*16 + MONTHY//10
Y = YEAR/10*16 + YEAR//10
I2cwrite SDA,SCL,%10100001,2,[0]
I2Cwrite SDA,SCL,%10100001,3,[M]
I2Cwrite SDA,SCL,%10100001,4,[H]
I2CWRITE SDA,SCL,%10100001,5,[D]
I2CWRITE SDA,SCL,%10100001,6,[Mn]
I2CWRITE SDA,SCL,%10100001,7,[Y]
I'm trying to make a propeller clock with 22 LEDs and was wondering if I can help with handcuffs programming ...:confused:... in part to pass the information that the PCF8583 fornesi my PIC (16F877) and passes it to the LEDs ... was shackled to help me say something ... thanks;)
ps.: I'm working with miKroC
Hi, East
You could find much better help on the ... MikroC Forum.
Here: http://www.mikroe.com/forum/viewforum.php?f=13
Don't you think ???
Dear EAST
a "propeller clock with 22 LEDs" is a diferent project.
It´s not similar than LCD clock, like my code was describe.
I am sorry, but it's very dferent.
Thanks to all...;)
