' PIC Defines
@ DEVICE pic16F628a, INTRC_OSC
' System Clock Options
@ DEVICE pic16F628a, WDT_OFF
' Watchdog Timer
@ DEVICE pic16F628a, PWRT_ON
' Power-On Timer
@ DEVICE pic16F628a, BOD_OFF
' Brown-Out Detect
@ DEVICE pic16F628a, LVP_OFF
' Low-Voltage Programming
@ DEVICE pic16F628a, CPD_OFF
' Data Memory Code Protect
@ DEVICE pic16F628a, PROTECT_OFF
' Program Code Protection
@ DEVICE pic16F628a, WRT_OFF
' Flash Memory Word Enable
@ DEVICE pic16F628a, DEBUG_OFF
' Debug
' Hardware Defines
LED1 var PortB.0
LED2 var PortB.1
LED3 var PortB.2
LED4 var PortB.3
LED5 var PortB.4
LED6 var PortB.5
LED7 var PortB.6
LED8 var PortB.7
LED9 var Porta.1
LED10 var Porta.2
' Initialse Hardware
PORTB=0
TRISB=0
PORTA=0
TRISA=0
' Main Program Loop
RandomValue var Word
Dice var Byte
RandomValue var 9876
Loop:
Random RandomValue ' Generate Random Value
Dice=(RandomValue//10)+1 ' Convert it to range 1-10
Pause 75 ' Debounce Delay for Button
If LED1 = 1 Then
Low LED1
Pause 5000
If LED2 = 2 Then
Low LED2
Pause 5000
If LED3 = 3 Then
Low LED3
Pause 5000
If LED4 = 4 Then
Low LED4
Pause 5000
If LED5 = 5 Then
Low LED5
Pause 5000
If LED6 = 6 Then
Low LED6
Pause 5000
If LED7 = 7 Then
Low LED7
Pause 5000
If LED8 = 8 Then
Low LED8
Pause 5000
If LED9 = 9 Then
Low LED9
Pause 5000
If LED10 = 10 Then
Low LED10
Pause 5000
GoTo Loop ' Do it again
This is the first time I have played with picbasic, so my code is most probably very wrong, but will help me to learn, please bear in mind that I am not super-intelligent
