For some reason the following code has no effect on outputs due to the pin labels:
If i Use the following:Code:InpA VAR PortB.4
InpB VAR PortB.5
InpC VAR PortB.6
InpD VAR PortB.7
LedA VAR PortA.2
LedB VAR PortA.3
LedC VAR PortA.4
LedD VAR PortA.5
RlyA VAR PortA.6
RlyB VAR PortA.7
RlyC VAR PortA.0
RlyD VAR PortA.1
StatusA VAR byte ' Port A Status Flag
StatusB VAR byte ' Port B Status Flag
StatusC VAR byte ' Port C Status Flag
StatusD VAR byte ' Port D Status Flag
CurrentPort VAR byte ' Current Port
StatusA = 0
StatusB = 0
StatusC = 0
StatusD = 0
LedA = 0
LedB = 0
LedC = 0
LedD = 0
CurrentPort = 1
Goto SetActivePort
checkports:
If InpA = 0 then
pause 50
If InpA = 0 then
StatusA = 0
Low LedA
Else
StatusA = 1
High LedA
If InpB = 0 then
pause 50
If InpB = 0 then
StatusB = 0
Low LedB
Else
StatusB = 1
High LedB
If InpC = 0 then
pause 50
If InpC = 0 then
StatusC = 0
Low LedC
Else
StatusC = 1
High LedC
If InpD = 0 then
pause 50
If InpD = 0 then
StatusD = 0
Low LedD
Else
StatusD = 1
High LedD
it seems to work fine,Code:
Goto SetActivePort
checkports:
If portb.4 = 0 then
pause 50
If portb.4 = 0 then
StatusA = 0
Low PORTB.3
Else
StatusA = 1
High PORTB.3
If PORTB.5 = 0 then
pause 50
If PORTB.5 = 0 then
StatusB = 0
Low PORTB.2
Else
StatusB = 1
High PORTB.2
If PORTB.6 = 0 then
pause 50
If PORTB.6 = 0 then
StatusC = 0
Low PORTB.1
Else
StatusC = 1
High PORTB.1
If PORTB.7 = 0 then
pause 50
If PORTB.7 = 0 then
StatusD = 0
Low PORTB.0
Else
StatusD = 1
High PORTB.0
is there anything obvious that i have missed?
