LCDOUT 4-bit data on 8-bit setting
Hey,
Im having trouble on a PIC16F88, as far as i can tell the code should be outputting the data on all eight pins of PORTB, but pins 4-7 are allways low, see the example below:
DEFINE OSC 8
Define LCD_DREG PORTB ' Port for LCD Data
Define LCD_DBIT 0 ' Starting Data bit (0 or 4) if 4-bit bus Use LOWER 4 bits of Port
Define LCD_RSREG PORTA ' Port for RegisterSelect (RS) bit
Define LCD_RSBIT 6 ' Port Pin for RS bit
Define LCD_EREG PORTA ' Port for Enable (E) bit
Define LCD_EBIT 7 ' Port Pin for E bit
Define LCB_BITS 8 ' Using 4-bit bus
Define LCD_LINES 4 ' Using 2 line Display
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 200 ' Data Delay (uS)
init:
OSCCON = %01110000 '8 MHz Internal Oscillator
Pause 2000 'Safe Start Up Delay
CMCON = 7
ADCON1 = 7
ANSEL = %00000000
TRISA = %00000000
TRISB = %00000000
PORTA = %00000000
PORTB = %00000000
LCDOUT %11111111
PAUSE 1000
Daniel
Typo is the likely cause !!!
The comment doesnt match the parameter specified but the real problem is that you have typed LCB instead of LCD
Because you dont have a valid DEFINE it is using the default value which is for 4 bits.
Hope that helps
Keith
