Advice please - data tables
I'm learing PBP and although its been a steep learning curve, the support of this forum has been great and I've taken onboard what I've been given.
I'm just playing about with the "flash some LEDs", basic stuff really, and I now have the basis for what could turn into a nice project for some disco lights. I've detailed my code below, which basically has a chase pattern, the speed of which is set by a 10k pot.
PORTA = 0 ' declare port level BEFORE port direction = safe power-on
CMCON = 7 ' PortA Digital inputs
CCP1CON = 0 ' PWM off
VRCON = 0 ' Voltage reference disabled
OPTION_REG.7 = 0
TRISA=%00000111 'set PORTA as all output apart from A0, A1 and A2
TRISB=%00000000 'set PORTB as all output
DATA @1,word 625,0,word 545,word 750 ' pre-setting EEPROM
@RC_OSC_NOCLKOUT
@WDT_ON
@PWRT_ON
@MCLR_OFF
@BOD_ON
@LVP_OFF
@CPD_OFF
@PROTECT_OFF
;set up varibles
PORTBbit var byte
i var byte ;used for for next loops
D var byte ;used to store the result of the pot on port A1
scale var byte ;used in the POT command
Scale = 254 ;used to set range
SW1 var PORTA.2 ;up switch
SW2 var PORTA.0 ;down switch
SWcount var byte ;used as a place holder for patterns
swcount=1 ;set place holder to default to pattern 1
;main program
Pot PORTA.1,scale,D ;used to read value from 10k pot
if sw1=0 then swcount=swcount+1 ;check to see if up button pressed
if sw2=0 then swcount=swcount-1 ;check to see if down button pressed
pause 120 ;debounce delay
If swcount>2 then swcount=2 ;error trap for exceeding max patterns
If SWcount<1 then swcount=1 ;error trap for exceeding min patterns
if swcount=1 then pattern1 ;goto selected pattern based on value
if swcount=2 then pattern2
pattern1: ;standard chase pattern 1 - 8
For PORTBbit=0 to 7
if D<5 then D=5 ;set the minimum pause time to 5ms
HIGH PORTBbit
pause D
LOW PORTBbit
pause D
Next
pattern2: ;standard pattern reveresed 8 -1
For PORTBbit=7 to 0 step -1
if D<5 then D=5
HIGH PORTBbit
pause D
LOW PORTBbit
pause D
Next
However now I would like to add further patterns and ideally store / code them as data strings or binary patters that are repeated, eg
[code]
10000001
01000010
00100100
00011000
00100100
01000010
10000001
or
129, 66, 36, 24, 36, 66,129
[code]
I've browswed through the manual, but can't see any clear reference on how to write these values in a loop to portB. ie something like
[code]
for i = 1 to number of steps
write value to port
make port high
delay
port low
next
[code]
My evential goal would be to use the UART in the chip to communicate with a PC and allow the additional patterns to be uploaded to the PIC.. but I think I had better learn to walk before I start running ;)
