		PIC18F458 Shiftin / Out
		Something wrong with the Shiftin Shiftout
 I have the following problem with the shiftin / out function.
 Pic used is a 18F458
 I used the port D to control an ADC Converter LTC1298 (D4-D7)
 and 2 relays (D3 D4) and leds (D0 D1)
 LEDNIGHT_Status     VAR PortDStatus.0
 LEDDAY_Status       vAR PortDStatus.1
 RELAYNIGHT_Status   VAR PortDStatus.2
 RELAYDAY_Status     VAR PortDStatus.3
 CS_Status           VAR PortDStatus.4
 SCLK_Status         VAR PortDStatus.5
 DIN_Status          VAR PortDStatus.6
 DOUT_Status         VAR PortDStatus.7
 All defined as out except PortD.6
 To read the ADC value, I used the following command
 CS_Status = 0
 PORTD = PortDStatus                     'Activate the ADC.
 shiftout PORTD.7,PORTD.5,lsbfirst,[config\4]  'Send config bits.
 shiftin PORTD.6,PORTD.5,msbpost,[Temp_VOLT\12] 'Get data bits.
 CS_Status = 1
 PORTD = PortDStatus                     'Deactivate the ADC.
 This works fine but if one of the ouptut D0-3 is set to 1 before the statement, the output will follow the CS_Status during the shifout or shiftin
 statement.
 Any idea ?
		In your programm, we see no definition of "PortAStatus" !
 Why do you put this undeclared value to PortD ?
		18F456 shiftin shiftout
		I don't use the Port A, so ..
 I just tried with another PIC just to see if I didn't had one hardware problem : just the same
 I then tried with a 18F452 instead of a 18F458.
 With this one , everything just works fine ....
		you need to disable analog comparator on PORTD<3:0> to avoid odd results first.
 CMCON=7
 about now?
		You're right. I forgot this.
 I tried again with the 458. It's works fine
