Problems with DTMF Generatiom
Hi Group-
I have a project going with 2 16F876's talking to each other via PSTN using DTMF tones. I use an MT8870 to decode, and the pbp DTMFout command to generate the DTMF tones.
I am having trouble with DTMF generation - I get flaky decoding with the DTMF tones produced by the 'PIC , but not if I use DTMF tones from a telephone, that works fine. This leads me to think that it's the DTMFtones from PBP that are the cause of the problem. Does anyone have any experience with the quality of the DTMF tones generated by PBP? Could it be because I'm not lowpass filtering the tones properly? I use the filter in the PBP manual (2 caps and 2 resistors) and an opamp to buffer. Any advice would be welcome.
Secondly, can anyone point me toward a supplier that will provide sample quantities of a DTMF generator chip such as the Holtek 9200 or Samsung EFG7189 - one with serial or parallel interface? Nobody in South Africa carries anything like this on the shelf. If I can't get the PIC right, I'll have to go the hardware way. Again, any advice would be welcome
Angus Anderson
