(1) If you're using the PORTB.0 interrupt, do you have to enable the PORTB pullups? If so, does it set the whole port or can you assign the pullups individually? (I'll have to use an external 10k...if I need to)
(2) When you come out of sleep and you see a high pulse on PORTB.0 and go to a routine.....at some point you need to reset the B.0 flag, right?
INTCON.1 = 0
1) You don't have to use the built-in pullups if you don't want to - but be sure to use an external pullup / pulldown as needed otherwise. The entire port has its pullups enabled as a group (other Pic models allow setting individual pin pullups). When a pin is switched to output mode, the individual port pin pullup is automatically disabled.
