voltage regulator help - ot
Sorry for the OT message, but you guys are great at answering my questions, and pretty quick at it.
Right now I am using LM317 voltage regulators to power my mosfets because each color of my RGB LED requires a separate voltage. The LM317 is only 1.5 amps & I would love to go up to the LM350 which is 3 amps. My main problem is that the heat generated by either one is enough that it requires a heatsink. I am using an aluminum enclosure and would love to bolt to it as a heatsink, but the tab shares output voltage which would cause problems with the grounded case.
Could anyone recommend other adjustable voltage regulators that might solve these problems? I see that the LM2650 doesnt require a heatsink, but it is SOIC and right now I am prototyping with all through hole stuff.
Anyway, I have only been working in the IC world for a few months now, so if anyone could shine some light on other magic IC's It would be great. Diging through the Digi-Key and Mouser catalogs is pretty tedious.
much thanks
brian
A swithcing regualtor is better for large current
I also had the heat problem with such linear regualtor. I was not able to find a good heat sink to remove the heat. The problem was solved after I change to a switch type regualtor (LM2575). Although the connection is more complicated, it brings good relibility to my control board.
