PIC12F683 Pinouts?
I am trying to write a simple program on a 12F683. Its my first time using a 8 pin PIC. I can't figure out how to do a TRIS. I am not able to get pin GP3 to work as an output and I can't get GP1 to work as an input. I only need AN0, which I have not tested yet. Anyone have any ideas what I'm missing. Code is below. Thanks
@ device INTRC_OSC_NOCLKOUT
@ DEVICE MCLR_OFF ' Master Clear Options
OSCCON = $60 'sets the oscillator speed
DEFINE OSC 4 'Oscillator speed in MHz
' Alias pins
LED_Sig VAR GPIO.3 ' LED - Rx Complete Flag
LED_Rx VAR GPIO.4 ' LED - I2C Data being written
LED_Tx VAR GPIO.5 ' LED - Serial Data Being Read
' Set up Analog
ADCON0 = %11000001 'AN0 Analog, rest digital
ANSEL = %00110001 'AN0 Analog, rest digital
INTCON = %00000000 'all interrupts OFF
' Define used register flags
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
' Allocate RAM
i VAR BYTE
for i = 1 to 10
high LED_Sig ' LED won't work... It works is I just jumper 5V to the PIN
pause 50
Low LED_Sig
pause 50
High LED_Rx
pause 50
low LED_Rx
pause 50
high LED_TX
pause 50
low LED_Tx
pause 50
next i
start:
if GPIO.1 = 1 then
low LED_Rx
high LED_Rx
if GPIO.2 = 1 then 'can't turn the LED off with 5V put right on the PIN
low LED_Tx
high LED_Tx
goto start
Cpayne,
GP3 can only be an input and never output (see datasheet section 4.1)
Add:
TRISIO = 3
to makes GP0(AN0) and GP1 inputs with the rest output (see datasheet section 4.1 again)
Good Luck,
Paul Borgmeier
Salt Lake City, Utah
USA
also, don't forget to disable the analog comparator...
section 8 of the datasheet...
