hello all
i work with a timer1 on a 16f876 at 20 mhz. i used such a snippet some other times succesful. on this other cases i've ever immedeatly start timer1. probaply so i never found this problem...
the problem is that i fall immeadetly to the interupt handler.
i have a longer while-wend in the pre loop to wait for some user inputs. timer1 should not start until end of pre loop.
i've tested also with the ICD, where i saw that PIR1.0 is set to 1 on boot up and also after reset in interrupt handler it goes back very (too) fast. i've also try with PIR1.0 = 0 at the begin of the code. no success
probaply i search on the wrong end, but i think from there is coming up the problem.
thanks for any hint. cheers, mischl
Code:... init
'-- PRE LOOP ----------------------------------------------------
while not ((buto = 3) and (dezi = 1))
.... stays longer here
wend
T1CON = %00000000 ' set timer1 prescaler as 1:1. stop timer1
PIR1.0 = 0 ' clear timer1 overflow flag
PIE1 = %00000001 ' enable interrupt on timer1 overflow
INTCON.6 = 1 ' enable peripheral (unmasked) interrupts
INTCON.7 = 1 ' enable global interrupts
gosub SetTimer ' start timer1
on interrupt goto handler ' handling interrupt
'-- MAIN LOOP ---------------------------------------------------
... do something
GOTO main
'-- INTERRUPT SERVICE ROUTINE ----------------------------------
disable interrupt ' disable interrupts in handler
handler:
gosub SetTimer
fram = fram + 1
if fram > 24 then
fram = 0
seco = seco + 1
if seco > 59 then
seco = 0
minu = minu + 1
if minu > 39 then
minu = 0
seco = 0
fram = 0
fcnt = fcnt + 1 ' inc frame counter
frsh = 1 ' set refresh lcd flag
resume main
SetTimer:
T1CON.0 = 0 ' stop timer1
TMR1H = $63 ' load with 25536 = 65536 - 40000
TMR1L = $c0
T1CON.0 = 1 ' start timer1
enable interrupt ' enable interrupts after handler
'-- SUB --------------------------------------------------------
