interrupt on USB com
I am trying to set-up a USB Interupt on a 18F4550. I want a programm interruption on USB bus activity. My problem it seems that i don't haveset the right register.
Ofr example : how do you access to UIE register in PBP ?
here is my
DEFINE OSC 48 ' oscillateur ‡ 48 Mhz
LEDalim VAR PORTA.4 ' LED alim
USBbuffer var byte
USBcount var byte
USBINIT ' initialise USB...
INTCON = %10000000 ' Enable RB0 interrupt
PIR2=0
bsf UIE,2 ' Is it right ?
endASM
ON INTERRUPT GOTO myint
loop
USBservice ' a simple loop /keep alive USB
goto loop
disable
myint:
DoUSBIn:
USBCount=1 ; 1 byte
USBSERVICE ' keep connection alive
USBIN 3, USBBuffer,USBCount,DoUSBIn ' read data, if available
DoUSBOut:
USBCount=1 ;
USBout 3, USBBuffer,1,DoUSBOut ' send data, if available
PIR2=0
resume
enable
Is there something wrong ?
For information : i used CDC comminication ( virtual COMport) and usually the USB communication work fine.
