write to EEPROM and interrupt
i use external interrupt in my programm, and i want to use WRITE command
but i must turn interrupt off or mask it before use WRITE command.
so, how can i do that?? should i put WRITE command at the beginning of the software? i mean before Main loop, or is there any simple methode to do it ??
pic16f84
WRITE_PRO:
WRITE 3,4
goto WRITE_PRO
OPTION_REG =%11000000
INTCON =%10010000
ON INTERRUPT GOTO INT
MAIN:
GOTO MAIN
Did i do the right or the wrong ??? because i want to put WRITE_PRO at any posion not at the beginning as i did
Re: write to EEPROM and interrupt
I'm going to try this. Thanks!
Also, does the same apply to EEPROM reads? I assume a READ instruction can get messed up if the interrupt occurs at just the right time during the READ?
swr999, I have used the "DEFINE WRITE_INT 1" directive with my 18F parts and have had no problems. The READ instructions are not to my knowlege prone to disruption with interrupts enabled.
Hi. Is this a PBP3 DEFINE? I don't see this in my PBP 2.60 manual. What does it do?
Thanks Dave. My "issue" is that I have a 10-mS interrupt running to keep track of elapsed time. I have several EEPROM writes and since EEPROM writes take a while I don't want to lose time by stopping the interrupt for every write.
I did a test program where I repeatedly wrote to EEPROM with a 'random' WORD. For each write I then read back the value that got stored in EEPROM. It turns out that the error rate due to interference from the interrupt was quite low, about 0.04% (~400 errors in a million writes). So what I ended up doing was to do each write with a call to a subroutine:
EEwriteWord:
WRITE addr,xW.byte0:WRITE addr+1,xW.byte1
READ addr,xR.byte0: READ addr+1,xR.byte1
IF xR != xW then
INTCON.7=0
INTCON.7=1
This seems to be working well. While the EEPROM write takes several mS the READ is pretty fast, so this doesn't add too much overhead.
rsocor01
DEFINE WRITE_INT 1 is used to avoid write errors during a WRITE to EEPROM which might otherwise possibly be caused by an interrupt occurring during the write. The functionality is that it disables interrupts just prior to executing a WRITE instruction, and re-enabls interrupts after the WRITE completes. Appears to be strictly a PBP3 feature.
With regard to the "DEFINE WRITE_INT 1" directive, it appears to be available at least from PBP 2.50 onwards. I misspoke above^^^. Apologies.
