Pic16f84(a) w/20 Mhz Osc Serin/out commands with PBC
I saw how to make an adjustment for different clock osc in PBP with the "def osc" command. How do I do that with PBC? I bought a relay board with the 20Mhz already installed and I want to use Serin and Serout commands to talk to a pc. I saw that the 20Mhz was 5x faster than the 4 Mhz and therefore would increase the speeds by 5, but I can't match up baud rates. So is there a way to tell PBC that I am using a 20Mhz clock so that I can match up baud rates?
