How to calculate machine time in basic code?
Ex.
Used 4 Mhz
If porta.0 =1 then
Portb.1=1
Else
Portb.2=1
Ex.
Used 4 Mhz
If porta.0 =1 then
Portb.1=1
Else
Portb.2=1
Execution Time Measurement
The oldest timing trick is to drive an output bit high when
entering a routine, and then low as we exit. Probe the port
with an oscilloscope and measure the time the bit is set.
You can run your PBP program in the MPLAB simulator and use the
StopWatch function to get the timing of the commands.
(Menu Debugger\Stopwatch).
Best regards,
Luciano
We Used microcode studio plus software
A way that I often use is to compare the execution against a hardware timer.
The example below works for an '8720 running at 20Mhz. You will have to modify accordingly if you use a different processor or XTAL.
DEFINE OSC 20
DEFINE NO_CLRWDT 1 ' Don't waste cycles clearing WDT
DEFINE _18F8720 1
DEFINE HSER_RCSTA 90H
DEFINE HSER_TXSTA 20H
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1
DEFINE LOADER_USED 1
Define USE_LFSR 1
TRISC = %10111111 ' Hardware serial port on PORTC.7,PORTC.6
PSPCON = %00000000 ' No PSP
MEMCON = %10000000 ' No External Memory
CMCON = %00000111 ' No Comparator used, turn it off
T0CON = %10001000 ' No Prescaler,16 bit
TimerValue VAR WORD
RealTime VAR WORD
TestArray VAR BYTE[3600]
DummyVal VAR Byte
Restart:
Intcon.2 = 0
TMR0H =0
TMR0L =0
'Put code to be timed here
TimerValue.LowByte = TMR0L
TimerValue.Highbyte = TMR0H
IF INTCON.2 = 1 THEN
HSEROUT ["OVERFLOW - User different prescaler value",13,10]
HSEROUT ["Execution Time = ",#TimerValue, " Cycles, ",#TimerValue/5," Microseconds",13,10,10]
HSEROUT ["Press any key to restart",13,10]
HSERIN [DummyVal]
GOTO Restart
