Write Read And Words
I'm running out of code space so.... (16F628)
What is the most efficient way to read & write a WORD using the READ, WRITE commands.
I have a VAR WORD which holds the VAR 1234
I need to write this and then read it at start up.
Is it possible to write the whole word in one instructions as it is 2 bytes.
I was hoping to do something like write [0,1],VAR
then read [0,1],VAR
But how do i get the whole WORD?
Any suggestions
Rob
You can only READ and WRITE a BYTE at a time. So your WORD must be split and handled in two steps...
WRITE 0,MyWord.LowByte
WRITE 1,MyWord.HighByte
and similarly to Read and assemble back into a WORD...
READ 0,MyWord.LowByte
READ 1,MyWord,HighByte
The PBP manual is quite explicit on the usage.
Melanie
Hi Melanie
I did read though the manual several time and didn't notice the byte0 command.
Again searching though the archives didn't show anything till I found the byte0 command.
It was only when I found the command I then found numerous postings.
Please don't think I'm being lazy I spent 4hrs looking though the archives and didn't find anything under eeprom, word etc.
Thanks for your helps once again
Rob
