What chip are you using?
>Its the 16F690
The interrupt control register should already be mapped in the INC file for that chip. This would be the name you use (instead of CONTROL) -> most likely INTCON.
Yes, I am dealing with INTCON too, in the usual way. The lines of code I wrote in the example just refer to the relevant parts of my program.
I use 'Control' to indicate certain functions have created an interupt. For example, if the Usart receives a byte of data I set Control,1. if the interupt is caused by a succesion of timer 1 overflows, enough to create a 1second time period I set bit Control,0.
I am doing it this way because i need the interupt accuracy for timing purposes, IE without the latency created when dealing with interupts through PBP.
Later, when the interupt is over, and at a time convenient to me (in programming terms) I check the bits of CONTROL and act accordingly
. In this way the data never overflows and the timing period is accurate regardles of what pbp instruction is being executed. Perhaps if executing a long pause statement 5 data bytes could be received, this would cause an overflow error.
As it is CONTROL is a variable and when you do
bsf _CONTROL,1 you're trying to set the flag on the register located at CONTROL (whatever that value happens to be at the time).
> Erm, I'm not quite sure that's entirely true. The command actually sets bit number 1 in the address pointed to by the label CONTROL. That's what Microchip datasheets have always said anyway....
So depending on how that variable is defined (or initialized) you may be setting a flag in the INTCON register or some where else. When you read CONTROL.1 you're just reading the variable, not the register (see you never change the variable in assembly - you try to set the flag in the register pointed to by CONTROL).
> ah okay, i see what details you're saying I've got confused about, but it's not the case. CONTROL is declared as a user variable, and presumably pbp is assigning it to an address at or above $20. The INTCON register is at a lower address, and it has to be fair to assume that pbp absolutely does perform this action, otherwise it would never work.
I am going to be using FSR and INDF at a later point but it's commented out at the moment so that's not a cause of confusion at the moment.
Just look at the INC file, but it would probably be something like this:
asm
bsf INTCON,1
endasm
IF INTCON.1 =1 THEN
;do action
