Hi. I want to burn the config fuse on a PIC without disturbing the program data. How to I setup the programmer options to do this?
(I'm trying to set the code protection on an already programmed PIC)
Hamster
Hamster
Without knowing what programmer software you're using it's impossible to answer. On my part, the elnec software allows you to do this... but if you haven't got an elnec (or compatible) programmer that answer will be of no use to you.
