Dedicated LCD Controller question
I'm fairly new to PICS and have been working on making my own LCD controller out of a PIC16F84A(I had both the PIC and the 2x16 parallel lcd arleady, and couldn't see spending the $$ on a Serial LCD). I've got my circuit board built, using an 8-bit interface to the LCD. The pic runs at 20MHz.
I am using PBP v2.46, Microcode Studio, and the Melabs USB Programmer
My code for the 16F84A is:
@ DEVICE PIC16F84A, HS_OSC, PWRT_ON, WDT_OFF, PROTECT_OFF
DEFINE  OSC 20            ' Set speed to 20MHz
TRISB = %00000000          ' All PORTB pins are outputs
' LCD DEFINES
DEFINE  LCD_BITS    8
DEFINE  LCD_DREG    PORTB
DEFINE  LCD_DBIT    4       'PORTB.0 is first data
DEFINE  LCD_LINES   2       'Number of lines on LCD to be used
define LCD_RSREG    PORTA   'Port used for LCD RS Pin
define LCD_RSBIT    3       'Port Pin used for LCD
define LCD_EREG     PORTA   'Port used for LCD E pin
define LCD_EBIT     4       'Port Pin used for LCD E Pin
define LCD_COMMANDUS 2000   'Delay between sending lcd commands
define LCD_DATAUS   50      'Delay time between data sent
SerData	VAR word
SerPin 	VAR PORTA.2
TRISA.2=1
LCDOut $FE, 1	'Clear LCD
pause 20
lcdout $FE, 2   'Return to home position
pause 20
GOTO Start
Start:
     SERIN SerPin,6,SerData 'receive data
     LCDOut Serdata ' Send to LCD
     GOTO Start
I have another PIC (16F690) that I have hooked up to my "homemade lcd controller", using serout commands, and I can send data form the 16F690 to the lcd controller without any problems, but one thing that I cannot seem to figure out is how do I send the clear screen command , or any of the other commands that are listed in the PBP manual($FE, ) from the 16F690 to the 16F84A LCD controller?
		My LCD with Pic16f688 (Work good)
		INCLUDE "modedefs.bas"
OSCCON=$70
DEFINE OSC 8
define LCD_DREG PORTC
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 5
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
BO VAR byte
ANSEL=0
CMCON0=7
LOW PORTA.4
LCDOUT $FE,1,"LCD 1.0v"
  HIGH PORTA.2 'Back LED
LCDStart:
  serin PORTC.5,N2400,BO
  lcdout BO
goto LCDStart
		You problem was the same as mine
		Except I am still having trouble making my unit work and a day has passed without anybody contributing significantly to my inquiry.
Perhaps you would be so kind as to share your success.
My post was made to this forum on 22 Feb. 06
