Decoding DMX with picbasic pro
hello,
I have studied the posts concerning dmx with picbasic, I want to dimming a led on portC.5 on a 18F452. I try this basic code but unfortunately it doesn't run.
the dmx is converted by a driver SN75176 connected on pin 26 (RC.7/RX/DT). Please is someone can look my code for help me.
sorry for my bad english i'm french..... ;)
greating
'* Name : UNTITLED.BAS *
'* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 26/01/2006 *
'* Version : 1.0 *
'* Notes : *
DEFINE OSC 16 ' for pic 18f452
DEFINE HSER_BAUD 250000
DEFINE HSER_CLROERR 1
ERRORLEVEL -306, -302
' Variables diverves
counter VAR word ' Variable de travail WORD
idleflag VAR WORD
dummy VAR WORD
RCIF VAR byte
startcode VAR WORD
aminus VAR WORD
adresse_grada VAR WORD
x VAR WORD
newlevel1 VAR WORD
adresse_grada = 20
'This next routine is called on a gosub from my main housekeeping loop:
checkdmx:
counter = 1 'just a dummy variable
pulsin portc.7,0,counter 'here I'm looking for the break signal
if counter = 0 then
idleflag = 1 'either no dmx, or break was too long to count
'return
if counter < 40 then checkdmx 'watching for 'break
'if you get here, an active low pulse was detected, but it was too short.
'probably just part of the datastream. So go back and look again.
'otherwise, a valid break was found and it's time to read the start code
dummy = RCREG 'clear out any garbage which may be in the USART
dummy = RCREG
SPBRG = 0
TXSTA.2 = 0 'brgh = 0
TXSTA.4 = 0
RCSTA.7 = 1
RCSTA.6 = 0 'setting 8 bit receive mode, no parity, etc
RCSTA.4 = 0 'check the datasheet to see what all these bits do
RCSTA.4 = 1 'now, the USART is on and ready to receive
while RCIF = 0:wend 'hover here after break, before start code
startcode = RCREG 'This is the first byte received after the break
if startcode <> 0 then checkdmx 'do your own stuff here on a non-zero code
aminus = adresse_grada - 1 'address1 is my target address
for x = 1 to aminus 'set up a loop to count almost to the address
while RCIF = 0:WEND 'sit here until a byte is received
dummy = RCREG 'stash the byte somewhere unimportant
next x
newlevel1 = RCREG 'This is your target channel data
pwm portc.5, newlevel1 ,100 'i want dimming a LED on PORTC.5
RCSTA.7 = 0 'turn off the USART
goto checkdmx
