Usually, I add 10K pull up resistor for an input.
Is it a must to keep an input positive (high) to detect negative (low) when a button is pressed? (or the other way around)
Is there another way to eliminate the resistor by adding some kind of “define” or couple of lines into the code? I just don't want to use the resistor.
Thanks in advance
