Input not working with PIC12F675
I'm trying to get the hang of PIC programming, so I made a really simple circuit with two leds on port 1 and 2, and a switch on port 0 (connected so that pin 0 is high when the switch is open. The pin is connected to the positive terminal via a 10k resistor, and to ground via the switch).
The code segment I use is:
c VAR BYTE
c = PORTA
IF c.0 = 0 Then loop2
What have I done wrong? I have also tried the button command, and using pin 4 instead, still not working. Please help me!
/Henrik
