Midi cc controller!
Hi!
I am using a 16f84a with 20mhz to control 10 pots and send the corresponding midi cc message, but the pot command seems to be too slow and if i move the pot very fast it skips many messages! The 10kb pots are connected with a 0.1uf cap. I don't want to change the 16f84a because i have a bunch of them,so how could i fix the problem?
thanks in advance
Worst case scenario:
pot at 10K with 100nF gives 1msec time constant.
10 pots x 1msec gives 10msec plus your commands in the programm.
So you cannot get rapid reply with this method. A PIC with ADC I 'm afraid is what you need here.
Thanks a a lot Ioannis.
If i substitute the cap with a smaller one?
Yes you can I suppose use smaller caps but I have not checked it. I guess from the idea of implementing that kind of adc the range is limited. I would not try smaller than half the 100nf. I feel that you may have to use a fast analog to digital converter or at least try a PIC with an adc.
I think i'll try some other pic like 16f88 or better the 16f876!
thanks a lot
