newbie and array
I made IR receiver board with lcd. It works and I found codes for remote that i will be using. I used example from web to read values from IR. Now I have 8 bit value in array that is stored like:
if IRpulse_length[9] < 100 then
Command[0] = 0
Else
Command[0] = 1
It goes from Command[0] to Command [7] and fills array.
I managed to display it on lcd using
for i = 0 to 7
print at 1,i+1, bin Command[i]
next i
Question is now that i know that for example play button is 00001000 how can i compare it with array. I tried diferent combinations with val(array1,bin) etc etc but nothing is working...
