The PBP manual states that the clock speed for shiftin and shift out is about 50kHz, "depending on the oscillator". If I use a 20Mhz crystal, does this increase the clock speed linearly (i.e. assuming a 50kHz clock speed for a common 4Mhz osc, then would the clock speed increase to 250kHz for a 20Mhz xtal?), or does the compiler take the oscillator speed into account (with the define osc X statement) to compensate?
