Hi All,
I am new to the forum, and pretty new to PBP. I don't know if this is the right place to post this question. If it is not, better send me to the right spot because I have lots more coming.
So far PBP has been great to use. The manual is perhaps a bit sparse when it comes to the explanation of the commands. If I should be looking in different documentation please advise.
If using the PULSEOUT command does the program stop running for the duration of the pulse? I want to make a pin go high and some time later go low. The timing of this pulse is critical, and there is not enough time to sit and wait for the period to pass, lots of other tasks must continue while this pin is high. The period the pin is high varies a lot, so I can't try to run other pieces of code by 'squeezing them in'.
Thanks for your help
