gosub and if-then working together?
In the following bit of code there is a delay while waiting for a button to be pressed. If any of the buttons is pressed before the delay is up then a second routine is called to make a sound.
It works as I have written it, but I have noticed that the first loop that is looking for the button presses appears to "reset" if one is pressed and starts the counting again.
Is this normal operation when used this way? I'd just like to know. I know I could re-write this bit to remove that affect, but being still green on this I'm curious as to the why behind it.
Thanks.
Bart
errorcheck:
for loop = 1 to 4000 ' short delay once sound program is selected
getbutton = GPIO & %00110101 ' get port values and keep only ports 0,2,4,5
pause 1
if getbutton <> 0 then gosub errortone ' if a button is pressed play error tone
next
return ' return after delay and/or error routine
errortone: ' routine to produce a tone for any errors encountered
for loop = 1 to 3
pause 16
sound TRANSDUCER, [75, 5, 135, 5, 75, 2]
next loop
