2 Attachment(s)
16F18446 - setting baudrate for HW EUSART
Hi All,
I had an example from Richard lately where he configured my 16F18446 HW serial's port.
I didn't pay that much attention to it...
Now that I'm looking closer on "how he did it", I can't figure it out.
So I went to "visit" the DS and after lots of calculations and trials, I'm still stuck.
This is an extract from Richard's code (as said from another thread/project), the piece of code I'm working on.
' ====== PIC 16F18446 FUSES =======================================================================
' Internal oscillator
__config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
__config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
__config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
__config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
__config _CONFIG5, _CP_OFF
@ ERRORLEVEL -306
@ ERRORLEVEL -202
' ====== DEFINES / REGISTERS ======================================================================
DEFINE OSC 32
DEFINE ADC_BITS 12 'Number of bits in ADCIN result
DEFINE HSER_TXSTA 24h 'Enable transmit, BRGH = 1
DEFINE HSER_CLROERR 1 'Clear overflow automatically
BAUDCON.3 = 1 'Enable 16 bit baudrate generator
' Baudrates @ 32MHz
' 9600
'DEFINE HSER_SPBRG 832
'SP1BRGH = 51
' 19200
''DEFINE HSER_SPBRG 416
'SP1BRGH = 25
' 57600
'DEFINE HSER_SPBRG 138
SP1BRGH = 0
' 115200
'DEFINE HSER_SPBRG 68
'SP1BRGH = 0
' ====== VARIABLES ================================================================================
RC3PPS = 15 'TX PORTC.3 - set RC3 to EUSART TX
' ====== TEST PROGRAM =============================================================================
HW_SERIAL:
HSerout ["Hello World!",13,10]
HSerout ["Testing...",13,10]
PAUSE 1000
GOTO HW_SERIAL:
While the settings for baudrates 57600 and 115200 work perfectly, I can't make it work for slower baudrates like 19200 or even 9600.
I tried to follow the DS and, even if in Richard's example some values don't chage like for instance the SP1BRGH on, I thought I should use the following formula.
Attachment 10031
It doesn't work.
But looking at the baudrate examples table, I can't find the difference for all proposed baudrates.
Attachment 10032
Can anyone please explain whre I'm missing the point (or points)?
Re: 16F18446 - setting baudrate for HW EUSART
when you get a result like
DEFINE HSER_SPBRG 832 you realize something is very wrong since an 8 bit register can not accept that value ever
you have enabled the 16 bit baud rate generator in every case
for 19200
SP1BRGL = 160:SP1BRGH = 1
for 9600
SP1BRGL = 64:SP1BRGH = 3
BAUDCON.3 = 0 '8 bit baudrate generator
for 9600
SP1BRGH = 51
for 19200
SP1BRGH = 25
its probably better to say
there are two baudrate clock source dividers brgh=0 ; fosc/64 and brgh=1 ; fosc/16 and
and you have the choice of 8 or 16 bit baud rate generators, so 4 options for every baud rate
brgh=1
for 19200
for 9600
brgh=0
for 19200
SP1BRGL = 103:SP1BRGH =0
for 9600
SP1BRGL = 207:SP1BRGH = 0
brgh=1
for 9600
SP1BRG = 207
for 19200
SP1BRG = 103
brgh=0
for 9600
SP1BRG = 51
for 19200
SP1BRG = 25
Thanks a lot Richard.
All your settings work like a charm :wink:
Still a question: why would one choose the 8 bit baudrate generator - seems less accurate, no?
in reality accuracy is not always critically important, 1% or larger errors still work well in 90% of cases for tty serial transmission.
8bit generator results can be equally accurate anyway.
if you want to switch between rates rapidly a 8bit change is twice as quick to implement as a 16 bit one
