Help with Pololu DRV8711 Stepper Motor Driver
Hello - I am trying to write a simple program to run a stepper motor back and forth using the Pololu DRV8711 driver (Link: https://www.pololu.com/product/3730). In order to use the driver, you must first enable it and then you can use the DIR and Step Pins to run your stepper. With other drivers, all you needed to do was drive the ENABLE pin high and you were good to go. With the 8711 board, you have to enable it via SPI. This is done by sending 16-bit values to the registers on the board. Page 27 of the data sheet for this (Link: https://www.ti.com/lit/ds/symlink/drv8711.pdf) shows the registers and gives the default values. Technically, all I should have to do is to set bit 0 of the CTRL register to 1 and that should enable the motor, correct? I also want to limit the current to 1/2 of it's maximum value of 4A. This is done using the lower 8 bits of the TORQUE register. Here is my routine to do that:
InitStepper1:
'Set current to 1/2 max (2A)
'$1180 = %0001000110000000
high M1SCS
Shiftout m1SDAT, M1SCLK, 1, [$1180/16]
low M1SCS
pause 50
'Enable Motor
'$0C11 = %0000110000010001
high M1SCS
Shiftout m1SDAT, M1SCLK, 1, [$0C11/16]
low M1SCS
I am leaving all of the other values at their default. After executing the InitStepper1 code, I go to stepping the motor by pulsing the STEP pin and nothing happens. My stepper spins freely and I get no indication from my power supply that there is any additional current draw. Is there something I am not doing or doing wrong? Thanks! Jeff
Re: Help with Pololu DRV8711 Stepper Motor Driver
Looks like you're shifting out $1180 divided by 16, truncated to 8 bits, so $22. That's not what you want, is it?
Be careful with / vs \ ;-)
THANKS! Good catch and yes, I feel stupid. I will give this a try and let you know if that was it! Jeff
Well, While that was a problem, it was not THE problem. Still no movement. I tried both mode 1 and mode 0 for the SHIFTOUT methods, also, to no avail.
Here is a snip of the circuit board design for examination. It seems pretty straight forward, so I think my issue is with setting the registers. Any thoughts are appreciated.
NOTES: There are 2 drivers on board. Green traces = 5V, Blue = Gnd, Red = 12V, Black = Signal. PIC = PIC16F877A. Thanks!
Attachment 9972
Hmm...PortA...have you disabled the analog functions (ADCON1 and CMCON registers, I believe)?
Have you verified (logic analyzer or scope) that the expected data does appears on the pins?
Yes, I did set ADCON1 and no, I have not used a scope on this yet. Here is the entire code. I am simply trying to initialize the driver and run a stepper back and forth with 2 LEDs that indicate which direction. I really feel that there is some initialization that I am not doing or not doing correctly. Other than setting the torque and enabling the driver, I am using all the other register defaults... Thanks!
DEFINE OSC 20
@ DEVICE HS_OSC
TRISA = %00000000
TRISB = %10111111
TRISC = %01110000
TRISD = %00000000
TRISE = %00000000
ADCON1 = 7 ' Set PortA Pins as I/O pins
' M1 = Stepper1
M1SCS var PORTB.6
M1SCLK var PORTA.0
M1SDAT var PORTA.1
M1DIR Var PORTA.2
M1STEP var PORTA.3
RedInd var PORTD.0
GrnInd var PORTD.1
Icnt var word
M1NumSteps var word
M1Delay var word 'delay between steps - 250-12500 uS
' CTRL Register
' EnableON = %0000110000010001 '$0C11
' EnableOFF = %0000110000010000 '$0C10
' Torque Register
' Torque50 = %0001000110000000 'Set current at 50% (2A) $1180
' Torque100 = %0001000111111111 'Set current at 100% (4A) $11FF
low RedInd
low GrnInd
low M1SCS ' Set reset pin low
low M1Sclk ' Set clock pin low
low M1Step
goto TestStepper1
TestStepper1:
gosub InitStepper1
M1numsteps = 4000
M1Delay = 5000 'uS between steps
DoAgain1:
high RedInd
low GrnInd
low M1DIR 'CW
for icnt = 1 to M1numsteps
high M1step
pauseus 10
low M1Step
pauseus M1Delay
next
low RedInd
low GrnInd
low RedInd
high GrnInd
high M1DIR 'CCW
high M1step
pauseus 10
low M1Step
pauseus M1Delay
next
low RedInd
low GrnInd
goto DoAgain1
InitStepper1:
high M1SCS
Shiftout m1SDAT, M1SCLK, 0, [$1180\16]
low M1SCS
pause 50
'Enable Motor
high M1SCS
Shiftout m1SDAT, M1SCLK, 0, [$0C11\16]
low M1SCS
looks like it wants MSB first..... mode 1 on shiftout ???
Amgen - Thanks for your input. Yes, I have tried both Mode 0 and 1 with no luck. I have also tried reversing the SCS pin (low, shiftout, high as opposed to high, shiftout, low) and nothing there either. I still think there is something in one of the registers that I am not setting correctly...
OK - Problem solved. I went to Pololu and got help from their tech folks and they helped me figure this out. In a nutshell, it had to do with how I was creating the CTRL and TORQUE registers and sending them out. If you want to see how that all played out, just go to this link: https://forum.pololu.com/t/using-a-d...c-pro/27792/13. Don't see any reason to re-hash it here. In any event, I am now able to set the registers and control my stepper nicely. Here is my updated code that should get you started. The Pololu PNs for these boards is 3730 and 3731. Enjoy!
'* Name : Pololu Stepper-DRV8711.BAS *
'* Author : Jeff Wheat *
'* Date : 05/21/2025 *
'* Version : 1.0 *
'* Notes : PIC16F876A *
'* : Uses Pololu 4&8A Driver Boards *
@ DEVICE HS_OSC
DEFINE OSC 20
TRISA = 0
TRISB = 0
TRISC = %00001111
' Define the LCD Hookup parameters
' data pins D4-D7 are hooked to pins B.0-B.3, respectively
define LCD_DREG PORTB 'Data Port = PORTB
define LCD_DBIT 0 'Data starting bit = 0
define LCD_RSREG PORTB 'Register Select Port = PORTB
define LCD_RSBIT 7 'RS bit = PortB.7
define LCD_EREG PORTB 'Enable Port = PORTB
Define LCD_EBIT 4 'Enable Bit = PortB.4
define LCD_BITS 4 'LCD Bus Size = 4
define LCD_LINES 2 'Number of lines on LCD
MenuBtn var PORTC.0
UpBtn var PORTC.2
DnBtn var PORTC.1
EnterBtn var PORTC.3
DirPin var PORTA.3
StepPin var PORTA.5
SDATO var PORTA.1 'connect to SDATI pin on driver board
SDATI var PORTA.2 'connect to SDATO pin on driver board
SCLK var PORTA.0
SCS var PORTC.7
Icnt var word
StepDelay var word
StepMode var byte
NumSteps var word
DataOut var word
DataIn var word
Line1 con $80
Line2 con $C0
LSBFirst con 0
MSBFirst con 1
low steppin
low DirPin
low SCS
LCDOUT $FE, 1 ' Clear LCD screen
pause 20
lcdout $FE, line1, " Pololu Stepper "
lcdout $FE, line2, " Board - DRV8711"
pause 2000
LCDOUT $FE, 1
gosub InitStepper
pause 50
' Gosub ReadRegisters
' Stop
Numsteps = 4000
StepDelay = 500 'uS between steps
Start:
lcdout $FE, line1, "Dir = CW "
low DIRpin 'CW
for icnt = 1 to numsteps
high stepPin
pauseus 10
low StepPin
pauseus StepDelay
next
lcdout $FE, line1, "Dir = CCW"
high DIRpin 'CCW
high steppin
pauseus 10
low Steppin
pauseus StepDelay
next
goto Start
ReadRegisters:
'Read CTRL register 000
DataIn = 0
DataOut = %1000
high SCS
Shiftout SDATO, SCLK, MSBFirst, [DataOut\4]
Shiftin SDATI, SCLK, MSBFirst, [DataIn\12]
low SCS
lcdout $FE, line1, bin DataIn 'Display result in binary
'read TORQUE register 001
DataIn = 0
DataOut = %1001
high SCS
low SCS
lcdout $FE, line2, bin DataIn
InitStepper:
'TORQUE Register - Set current to 1/2 max (2A for 36v4 and 4A for 36v8)
' BIT0 BIT15
'DataOut = %0 001 0 000 11011111
DataOut = %0001000011011111
high SCS
Shiftout SDATO, SCLK, MSBFirst, [DataOut\16]
low SCS
'CTRL Register - Enable Motor
'DataOut = %0 000 11 11 0 0010 0 0 1
'DataOut = %0000111100000001 'full step
DataOut = %0000111100001001 '1/2 step
'DataOut = %0000111100010001 '1/4 step
high SCS
low SCS
