Trouble setting 16F1939 to 32mhz with intosc. (PLL X4 not working)
Hello.
This is my config:
;----[16F1937 Hardware Configuration]-------------------------------------------
#IF __PROCESSOR__ = "16F1939"
#DEFINE MCU_FOUND 1
cfg1 = _FOSC_INTOSC ; INTOSC oscillator: I/O function on CLKIN pin
cfg1&= _WDTE_OFF ; WDT disabled
cfg1&= _PWRTE_OFF ; PWRT disabled
cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
cfg1&= _CP_ON ; Program memory code protection is enabled
cfg1&= _CPD_OFF ; Data memory code protection is disabled
cfg1&= _BOREN_OFF ; Brown-out Reset disabled
cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
cfg1&= _IESO_ON ; Internal/External Switchover mode is enabled
cfg1&= _FCMEN_ON ; Fail-Safe Clock Monitor is enabled
__CONFIG _CONFIG1, cfg1
cfg2 = _WRT_OFF ; Write protection off
cfg2&= _VCAPEN_OFF ; All VCAP pin functionality is disabled
cfg2&= _PLLEN_ON ; 4x PLL enabled
cfg2&= _STVREN_ON ; Stack Overflow or Underflow will cause a Reset
cfg2&= _BORV_19 ; Brown-out Reset Voltage (Vbor), low trip point selected.
cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
__CONFIG _CONFIG2, cfg2
#ENDIF
;----[Verify Configs have been specified for Selected Processor]----------------
; Note: Only include this routine once, after all #CONFIG blocks
#IFNDEF MCU_FOUND
#ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
#ENDIF
'nixie led clock electronics direct drive
DEFINE ADC_BITS 10 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
ADCON1=%11110011 'enable adc internal reference and justify
FVRCON=%11001111 'set internal reference to 4.096V
OSCCON=%11110001 'SET INTOSC TO 8MHZ and enable 4X PLL
ANSELE=%00000001 'enable adc input porte.0
ANSELA=%00000000 'disable ADC on A
ANSELB=%00000000 'disable ADC on B
ANSELD=%00000000 'disable ADC on D
TRISC=%00000000 'set PORTC as output all
TRISD=%00000000 'set PORTD as output all
TRISB=%00000000 'set PORTB as output all
TRISA=%00000000 'set PORTA 2 as input, others as output
TRISE=%00000001 'set PORTE as output all except 0
WPUB=%00000000 'DISABLE B PULL UPS
OPTION_REG=%100000000 'disable other pull ups
LCDCON=%00000000 'disable LCD controller pins
LCDSE0=%00000000
LCDSE1=%00000000
LCDSE2=%00000000
DEFINE OSC 32 'set oscillator speed
It should run on 32mhz (8mhz clock * 4x PLL). However, it runs on 8mhz. If I set it to 16mhz, it works fine on 16mhz. So I guess, somehow, PLL setting is ignored. What I'm doing wrong?
I tried to play with PLL registers, but no luck...
Re: Trouble setting 16F1939 to 32mhz with intosc. (PLL X4 not working)
If PLLEN in Configuration Words = 1, SPLLEN bit is ignored. 4x PLL is always enabled (subject to oscillator requirements)
why are selecting Timer1 oscillator for fosc ? its incapable of 32mhz operation or pll
Thanks!
Yes it was my error - set OSCCON=%11110000 and now it seems to be working correctly.
