1Wire conversion
I am working with a pair of DS1820 temperature sensors. I need to display the temperature on a Sure 0832 dot matrix display. This means I need to take the DS1820 output and break it into each decimal digit of the resulting temperature. The 1Wire output is in 16 bit sign-extended 2,s complement number. I’m not sure about the best approach to this problem.
I could shift off bit 0-3 and have the next eight bits Binary if the S bit is 0. then I would have to convert to Decimal or use a lookup table. Once in Decimal I must breakout each digit of the number to send it to the display. This makes me wonder how PBP3 handles this conversion in “lcdout” to display in decimal. Is there a better method. Comments Please!
Wayne
Re: 1Wire conversion
first off there are ds18s20 and ds18b20 devices each would need slightly different treatment.
then you need to decide the resolution and "sign" you wish to display.
if negative[below zero] temps are involved the the sign bit of the result must be properly accommodated before results are scaled.
once you have a unsigned scaled binary result pbp can extract the digits with the DIG function.
the digits can then be displayed along with the sign and decimal point if needed as you desired.
Thanks Richard, I had forgotten about the DIG function. Thanks for the reminder, I'll give it a try.
Continuing with the same project. I have run into this problem many times over the years and I have yet to understand it. Why does this "If Then" statement fail to compile.
if Bvar = 0 then Cimage
else Avar = Bvar
gosub GetImage
I can rewrite it in any form with the same results. It does not compile.
I get an error code "Endif without a If...Then statment. It seems like a no brainer but I just don't' understand what I'm doing wrong.
one of the reasons snippets are fairly useless is that assumptions have to be made, however assuming Cimage is a subroutine
the correct syntax is
if Bvar = 0 then
gosub Cimage
Avar = Bvar
gosub GetImage
Your right as always! Not very forgiving is it. The format doesn't seem to fallow that of other functions.
thanks Richard
I've been trying to find some code to extract the 64-bit serial code from the 1wire devise. I think DT posted this routine but I have been unable to find it. Can anyone help?
This one could be useful ...
'* Universal thermostat -25/+75 C. by R.T.G. van Steenis *
'* Compiler : PicBasic Pro 2.45 *
'* B0 = Mode switch in (In) A0 = LCD Enable (Out) *
'* B1 = + switch in (In) A1 = LCD RS (Out) *
'* B2 = - switch in (In) A2 = "Warm" Output (Out) *
'* B3 = Not connected (Out) A3 = "Cold" Output (Out) *
'* B4 = LCD Bit 4 (Out) A4 = DQ DS1820 (In) *
'* B5 = LCD Bit 5 (Out) *
'* B6 = LCD Bit 6 (Out) *
'* B7 = LCD Bit 7 (Out PIC16F877A Code size = 1966 Words *
'* Oscillator XT (4 MHz.) - Power up timer enabled - MCR enable *
'* LCD Defines for EasyPic5 & 16F877A *
'@ ERRORLEVEL -306
'@ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
' DEFINE LCD_DREG PORTB ' I/O port where LCD is connected
' DEFINE LCD_DBIT 0
' DEFINE LCD_RSREG PORTB
' DEFINE LCD_RSBIT 4 ' Register select pin
' DEFINE LCD_EREG PORTB
' DEFINE LCD_EBIT 5 ' Enable pin
' DEFINE LCD_BITS 4 ' 4-bit data bus
' DEFINE LCD_LINES 2 ' LCD has 2 character lines
' DEFINE OSC 8
' DEFINE BUTTON_PAUSE 100
''Pinout for EasyPic5
' Heat Var PORTC.0
' Cool Var PORTC.2
' Waitbit Var PortC.4
' DQ Var PORTE.2 ' One-wire data pin
' Mode_B Var PORTA.0 'Pullups ...
' UP_B Var PORTA.1
' DOWN_B Var PORTA.2
''Configs EasyPic5
'ADCON1 = 7 ' Set PORTD and PORTE to digital
'CMCON = 7 ' Comparators OFF
'PORTA = %00000111
'PORTB = 0
'PORTC = 0
'PORTD = 0
'PORTE = 0
'TRISA = %00000111
'TRISB = 0
'TRISC = 0
'TRISD = 0
'TRISE = %00000100
' Elektor LCD Defines
@ __CONFIG _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _CP_OFF
DEFINE LCD_DREG PORTB ' LCD on port B
DEFINE LCD_DBIT 4 ' Data bits B4..B7
DEFINE LCD_RSREG PORTA ' RS on PORTA
DEFINE LCD_RSBIT 1 ' RS on A1
DEFINE LCD_EREG PORTA ' E on PORTA
DEFINE LCD_EBIT 0 ' E on A0
DEFINE LCD_BITS 4 ' LCD 4 bit mode
DEFINE LCD_LINES 2 ' 2 line LCD display
'Pinout for Elektor
Heat Var PORTA.2
Cool Var PORTA.3
DQ Var PORTA.4 ' One-wire data pin
Mode_B Var PORTB.0
UP_B Var PORTB.1
DOWN_B Var PORTB.2
' I/o Settings
PORTA = 0
PORTB = 0
TRISA= %11110000 ' RA0..3=Outputs RA4=Input
TRISB= %00000111 ' RB0..RB2=Inputs, RB3..RB7=Outputs
CMCON=7 ' Disable comparators
' Variables
Temperature Var Word ' Temperature storage
TempC Var Word
Float Var Word
TargetTemp Var Word ' Desired Temperature
Hyst Var Word ' Hystereris
V Var Word ' Var. for display
Cadence Var Word
B1 Var Byte ' Byte for TargetTemp calculation
B2 Var Byte ' Byte for TargetTemp calculation
Sign Var Byte ' +/- sign
Mode Var Byte ' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
DS18B20_Bit Var Byte
FAM Var Byte
CRC Var Byte
ID Var Byte[7]
Twist Var Bit
Busy Var Bit
Disable_out Var Bit
' Resolution
'DS18B20_9bit CON %00011111 ' 93.75ms, 0.5°C
'DS18B20_10bit CON %00111111 ' 187.5ms, 0.25°C <-- My favorite
'DS18B20_11bit CON %01011111 ' 375ms, 0.125°C
'DS18B20_12bit CON %01111111 ' 750ms, 0.0625°C (default)
Resolution CON 12
Offset CON 300
'Initialization
SELECT CASE Resolution
Case 9
DS18B20_bit = %00011111 ' 93.75ms, 0.5°C
Cadence = 900
Case 10
DS18B20_bit = %00111111 ' 187.5ms, 0.25°C <-- My favourite
Cadence = 810
Case 11
DS18B20_bit = %01011111 ' 375ms, 0.125°C
Cadence = 625
Case 12
DS18B20_bit = %01111111 ' 750ms, 0.0625°C (default)
Cadence = 250
END SELECT
DATA 46, 224, 20 ' Temp MSB, TEMP LSB, Hysteresis DIV 10
Heat=0 ' Warm Output Low
Cool=0 ' Cold Output Low
Disable_out = 1
Mode=0 ' Temperature display mode
Twist = 0
' Program start
PAUSE 500
READ 0, B1 'READ TargetTemp MSB
READ 1, B2 'READ TargetTemp LSB
TargetTemp=B1*256+B2 ' Calculate TargetTemp value (Default=20.0 C.)
READ 2, B1 'READ Hysteresis
Hyst=10*B1 ' Calculate Hysteresis value (Default= 2.0 C.)
LCDOUT $FE, 1, $FE, $0C ' Clear display, cursor off
PAUSE 250
SensID:' Sensor Identification
OWOUT DQ, 1, [ $33 ] 'READ Chip Family code
OWIN DQ, 2, [ FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC]
IF FAM = $05 THEN
LCDOUT $FE,$80, "DS 2405 "
PAUSE 1000
LCDOUT $FE,$80, " CRC: ",HEX2 CRC," FAM: ", HEX2 FAM
' DS 1820 / DS 18S20
IF FAM = $10 THEN
LCDOUT $FE,$80, "DS 18S20/1820"
PAUSE 2000
' DS 18B20 Config
IF FAM = $28 THEN
LCDOUT $FE,$80, "DS 18B20 "
OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_bit] 'Skip ROM search and write N_bits
' resolution to scratch pad
'DS 18B20 PAR Test
HIGH DQ
PAUSE 10 'Keep DQ High for 10 ms
INPUT DQ
PAUSE 2000
' Show CRC and FAM
' Show ID
LCDOUT $FE,$C0," ID:",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6]
PAUSE 2000
' Clear Screen
LCDOUT $FE,1
MainLoop:
' Select and Save Function
If Mode_B=0 then ' Mode switch pressed
Pause 50 ' Debounce
LcdOut $FE, $8F, "*" ' Show that command is accepted
If Mode_B=0 then MainLoop ' Wait until button is released
Mode=Mode+1 ' Increment mode
If Mode=2 then ' Save Target Temperature (Mode1 -> Mode2)
WRITE 0,TargetTemp / 256 ' TargetTemp MSB
WRITE 1,TargetTemp MOD 256 ' TargetTemp LSB
EndIf
If Mode > 2 Then ' Save Hysteresis (Mode 2 -> Mode 0)
Mode=0 ' Only 0, 1, 2 are valid
WRITE 2, Hyst / 10 ' Divide Hyst value to fit in Byte
EndIf
EndIf
' set Temperature
If Mode =1 then ' Set Target Temperature
LcdOut $FE, $80, "SET TEMPERATURE " ' Show function
V=TargetTemp ' TargetTemp in V
Gosub SelectSign ' Select +/blank/-
Gosub DisplayTemp ' Display Target Temperature
If (UP_B=0) Or (DOWN_B=0) then ' Up or Down button pushed
' Decrease set Temp
If DOWN_B=0 then ' Down button
If TargetTemp > 7500 then ' Not lower than -25 C. (10000-MinTemp * 100)
TargetTemp=TargetTemp-25 ' Decrease temperuture with 0.25 C.
EndIf
EndIf
' Increase set Temp
If UP_B=0 then ' Up button
If TargetTemp < 17500 then ' Not higher than 75 C. (10000+MaxTemp * 100)
TargetTemp=TargetTemp+25 ' Increase temperature with 0.25 C.
EndIf
EndIf
' Display set Temp
GoSub SetTargetTemp ' Display TargetTemp and delay 0.25 Sec.
EndIf
EndIf
' Set Hysteresis
If Mode=2 then ' Set Hysteresis
LcdOut $FE, $80, "HYSTERESIS " ' Show function
Sign=" " ' No sign
V= 10000+Hyst ' Set value for V
Gosub DisplayTemp ' Display Hysteresis
If (UP_B=0) Or (DOWN_B=0) then ' Up or down button pushed
Sign=" " ' No sign for Hysteresis
' Decrease Hysteresis
If Hyst > 10 then Hyst=Hyst-10 ' Not less than 0.1 C.
EndIf
' Increase Hysteresis
If Hyst < 1000 then Hyst=Hyst+10 ' Not more than 10.0 C.
EndIf
' Scale and show Hysteresis
Pause 250 ' Delay 0.25 Sec.
EndIf
EndIf
' Wait for End setting
If Mode > 0 then Mainloop ' Setting TargetTemperature or Hysteresis
LcdOut $FE, $80, " TEMPERATURE " ' Show function
' Sensor Presence Test
LOW DQ ' OneWire line Low
PauseUs 480 ' Keep down for 480 µS
Input DQ ' Make Pin Input
PauseUs 70 ' Wait 70 µS
If DQ then ' No presence pulse from DS1820
LcdOut $FE, $1, "** No sensor! **" ' Show message
Disable_out = 1
Pause 500 ' Wait 0.5 Sec.
Goto MainLoop ' Check again
Endif
Pauseus 400 ' Wait 400µs more and see
IF DQ = 0 THEN
LcdOut $FE, $1, " sensor shorted!" ' Show message
Disable_out = 1
Endif
Disable_out = 0 ' Sensor Ok : Output allowed
' Temp reading
OWOut DQ, 1, [$CC, $44 ] ' Start temperature conversion
WaitBit = 1 ' Show conversion ON
' REPEAT
' OWIn DQ, 4, [Busy] ' Check for still busy converting
' UNTIL BUSY
' DS18B20 PAR Test
HIGH DQ
PAUSE ( 1000 - Cadence )
INPUT DQ
WaitBit = 0
' Conversion completed
OWOUT DQ, 1, [$CC, $BE ] ' Skip ROM search & read scratchpad memory
OWIN DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]'READ two bytes / end comms
PAUSE Cadence ' 1 Measure/s !!!
' Temperature Calculation
Convert_Temp:
IF FAM = $10 THEN Temperature = Temperature * 8
IF Temperature.15 THEN
Temperature = ~Temperature + 1
Twist = 1
TempC = ( Temperature & $7FF ) >> 4 ' Partie Entière '4
Float = ((Temperature.Lowbyte & $0F ) * 25 )>> 2 ' Partie décimale 100èmes
Temperature = TempC*100 + Float 'Préparation 1/100 degrés
IF Twist THEN
V= 10000 - Temperature ' 25 C=12500 0 C=10000 -10 C=9000
Twist = 0
V= 10000 + Temperature
EndIf
' Offset Correction for DS 1820
IF FAM = $10 THEN V = V + Offset
' Show status
IF NOT Disable_out THEN
If V < TargetTemp - Hyst then ' Below Target temperature - Hysteresis
Heat=1 ' Activate Warm Output
Cool=0 ' Deactivate Cold Output
EndIf
If V > TargetTemp + Hyst then ' Above Target temperature + Hysteresis
Heat=0 ' Deactivate Warm output
Cool=1 ' Activate Cold Output
EndIf
GoSub SelectSign ' +/blank/- Sign
GoSub DisplayTemp ' Temperature to LCD
Else
Heat = 0 : Cool = 0
Endif
Goto MainLoop ' Do it forever
' SUBROUTINES
SelectSign:
If v = 10000 then ' Temperature = 0 C.
Sign=" " ' No sign
Else
If v < 10000 then ' <> 0
Sign="-" ' Temperature below 0 C.
Else
Sign="+" ' Temperature above 0 C.
EndIf
EndIf
DisplayTemp:
If V >= 10000 then ' Above 0 C.
Temperature = V-10000
Else
Temperature = 10000-V ' Below 0 C.
EndIf
LcdOut $FE, $C0," ", Sign, DEC (Temperature / 100), ".", DEC2 Temperature,178,"C "
SetTargetTemp:
V=TargetTemp
Gosub SelectSign
Gosub DisplayTemp
Pause 250
I ran it aboard an EasyPic 5 Board ... but connections are described in the beginning of the listing ... :D
Got it working
Thanks Ace
