assembly error on DT interrupts
When assembling the DT Interrupts for the 18F, I get the following error.
[ASM ERROR] Symbol not previously defined (INT_ENTRY_H) (0) : Error[113]
Below is the code from DT's Interrupt code.
DEFINE INTHAND INT_ENTRY_H ' Context saving for High Priority Ints
DEFINE INTLHAND INT_ENTRY_L ' Context saving for Low Priority Ints
This is being used on a PIC18F46K80. Any idea why the assembler might be complaining? Has anyone else run into this?
-Thanks
Re: assembly error on DT interrupts
Zapman
Do you have a link to DT's code?
A copy of your code wouldn't hurt either.
It might help give us a clue to the problem.
Hello Demon,
the two line code snippet is from the interrupt code on this site. Downloads | Book of Interrupts
It is where the variable is defined and yet the assembler complains about it.
I was wondering if anyone else had this happen. It also shows up in the error file.
Paul
For one, there's an order to place the DT includes in your program.
And it would REALLY help to see your complete code.
Hello Demon.
here is the code. It does not show any errors for the main code but the DT interrupts when assembled gives the error code listed above.
CLEAR 'Clears memoryinclude "codesize.pbp" 'measure the size of the code.
Define Measure 1
'..... If any of these next three lines cause an error
'......Comment them out to fix the problem...
'......which variables are needed, depends on the chip you are using.......
wsave1 var byte $A0 system ;location for W if in bank0
wsave2 var byte $120 system ;location for W if in bank0
wsave3 var byte $1A0 system ;location for W if in bank0
INCLUDE "DT_INTS-18-k80.bas"; Basic Interrupt System
INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
'INCLUDE "ReEnterPBP-18LP.bas" ; Include if using Low Priority. PBP INTS
INCLUDE "modedefs.bas" 'defines modes for serial in and out
INCLUDE "ProfileGen3.pbp" 'Motion profile generator for motor move
INCLUDE "incPIDv1_5.pbp" 'include the PID controller
INCLUDE "CANBus.pbp" 'CAN bus header file
' Define clock speed
DEFINE OSC 20 ' clock frequency
DEFINE USE_HIGHPRIORITY 1 ' use high priority interrupts
'define USE_LOWPRIORITY 1 ' not using low priority interrupts
DEFINE WRITE_INT 1
' have to define this so interrupts are masked when doing EEPROM
' writes. It handles masking and un-masking
INTCON2.6 = 0 ' Int on falling edge
' External Interrupt 0 Edge Select bit
' Set up data direction registers for all the pins.
TRISA = 111111 ' Set PORTA RA6 is Osc output to crystal
TRISB = 101001 ' Set PORTB
TRISC = 010100 ' Set PORTC
TRISD = 000011 ' Set PORTD
TRISE = 111011 ' Set PORTE only lower 4 bits available
;----[High Priority Interrupts]----------------------------------------
INT_Handler TMR1_INT, _ClockCount, PBP, yes ;-- Timer Int.
INT_Handler INT0_INT, _MoveCmd, PBP, yes ;-- Flap Switch
INT_CREATE ; Creates High Priority interrupt processor
and this is the Interrupt code from DT's Interrupts.
'****************************************************************'* Name : DT_INTS-18-K80.bas *
'* Author : Darrel Taylor modified for PIC18F46K80 *
'* Notice : Copyright (c) 2003 *
'* Version : 1.0 MAR 21, 2022 *
'* Date : MAR 21, 2022 *
'* Versions: *
'* 1.0 : MAR 21, 2022 first version modified for PIC66K80 *
'* 3.3 : MAR 24, 2008 *
'* Corrects an initialization problem affecting the *
'* first pass if CLEAR is not used *
'* 3.2 : Aug 26, 2007 *
'* Update for PBP 2.50 using LONG's with PBPL *
'* Added many new INT sources *
'* 3.1 : JUL 18, 2006 *
'* Modified to handle smaller BANKA in the newer chips*
;DISABLE DEBUG
wsave var byte BANKA SYSTEM ' location for WREG
ssave var byte BANK0 SYSTEM ' location for STATUS register
bsave var byte BANK0 SYSTEM ' location for BSR register
psaveUH VAR BYTE BANK0 SYSTEM ' PCLATU Hi Pri.
psaveUL VAR BYTE BANK0 SYSTEM ' Lo Pri.
psaveH VAR BYTE BANK0 SYSTEM ' PCLATH Hi Pri.
psaveL VAR BYTE BANK0 SYSTEM ' Lo Pri.
fsave0H var WORD BANK0 SYSTEM ' locations for FSR registers
fsave1H var WORD BANK0 SYSTEM
fsave2H var WORD BANK0 SYSTEM
fsave0L var WORD BANK0 SYSTEM ' low priority FSR locations
fsave1L var WORD BANK0 SYSTEM
fsave2L var WORD BANK0 SYSTEM
RetAddrH VAR BYTE[3] BANKA SYSTEM ' 21-bit return address Hi Pri.
RetAddrL VAR BYTE[3] BANKA SYSTEM ' Lo Pri.
INT_Flags VAR BYTE BANKA SYSTEM
Serviced_H VAR INT_Flags.0
Serviced_L VAR INT_Flags.1
InHPint VAR INT_Flags.2
NoPriority VAR INT_Flags.3
INT_Flags = 0
goto OVER_DT_INTS_18
;____ Check for PBPL (PBP ver. 2.50 and above only)__________________________
PBPLongs_Used = 0
if (R1 - R0 == 4)
PBPLongs_Used = 1
; messg PBPL Used = 1
; nolist
;____ DEFINE available interrupt sources_____________________________________
The error is for the INTHAND not being defined but, as you can see it is.
Paul
Posting snippets is just a waste of time...
Thanks for that enlightening comment Ioannis. If I posted all the code it would be about 4000 lines worth of code. The original question had to do with the assembler complaining about the (INT_ENTRY_H) not being defined. The code snippets are because Demon requested them. They show that the (INT_ENTRY_H) is defined in DT's code. So the only question would be if my includes meet the requirements that Demon was speaking about.
Paul
My first guess is that you have a missing file that it is supposed to be in the same directory as the pbp file.
My second guess is that that PIC doesn't support the Darrel high priority interrupts. I have used a few new chips that don't like the Darrel interrupts. I would try your code with a 18F4550 first to see if it works, and go from there.
beginning to look like another stone soup exercise
Hello,
This "DT_INTS-18-k80.bas" and the matching re-enter file, did you download them from somewhere or are you trying to customize the default ones yourself?
I don't have those files and a simple search did not find them so I can't test much here except compiling a bare bones example with the standard DT-Ints-18 files and, needless to say, it compiles and assembles without errors.
CLEAR 'Clears memoryinclude "codesize.pbp" .
Define Measure 1
INCLUDE "DT_INTS-18.bas" ; Basic Interrupt System
DEFINE WRITE_INT 1
TRISA = %00111111 ' Set PORTA RA6 is Osc output to crystal
TRISB = %00101001 ' Set PORTB
TRISC = %00010100 ' Set PORTC
TRISD = %00000011 ' Set PORTD
TRISE = %00111011 ' Set PORTE only lower 4 bits available
';----[High Priority Interrupts]----------------------------------------
GOTO Main
' Interrupt service routine
ClockCount:
LATA.0 = !LATA.0
@ INT_RETURN
MoveCmd:
LATB.0 = !LATB.0
@ INT_RETURN
If you try the above with the stock DT-Ints files, does it compile? If you try with your K80-version of the DT-Ints files, does it compile?
Hello Henrik,
I tried to compile the original DT Interrupt file linked from the DT Interrupts tab above. It generated the same error as I listed in my first post. It says that the "INTHAND" was not previously defined. As you can see from the code listed on the DT Interrupts page, INTHAND was defined. It is not a processor problem because it reproduces with different processors. I am using the PIC18F46K80. It does not complain about the INTLHAN definition so I don't know what is going on here. I removed all my files and tried to compile just the original DT interrupts and got the same error.
Paul
Something is wrong here... It sounds like you're trying to compile the DT-Ints file by itself, is that the case? If so, just stop doing that. They're not meant to compile by themself, they must be "fed" with information from the program in which they are used, namely the names of entry point for various interrupts, ie the INT_LIST macro (the part shown below).
No, that's not what you're doing. OK, moving on...
Like I said in my previous post, the code I posted does compile for the K80 using the stock DT-Ints-18 files.
If you look closely the DEFINE USE_LOWPRIORITY is commented so not in play (same in your code above). If I uncomment that line I get Symbol not previously defined (INT_ENTRY_L) because I'm telling DT-Ints that I want to use low priority interrupts but have none defined.
Then, if I remove the whole interrupt declaration part, ie
I get both Symbol not previously defined (INT_ENTRY_L) and Symbol not previously defined (INT_ENTRY_H), again because I've now not told DT-Ints which interrupt handlers I want "connected" with what interrupts.
PCzar3
Paul
Well, we are here to help on specific problems, not guessing what you might have wrong in your listing. If it is 4k long line let it be.
There are many kind people here that will have a second look at your code and surely might find that comma or dot it should or shouldn't be there for you.
If you like guessing work then be it...
Hello Ioannis,
I have worked with Henrik in the past and he has been most helpful. I'll look again at what he has suggested. If I find the solution, I'll post an answer. If not, well I'll have to see what I can find. I don't mean to raise your ire with my problem.
Paul
There is no ire...
Only that it is extremely difficult to guess what you might have wrong. Posting the listing and the in some cases the wiring to your PIC, power supply etc greatly helps nailing the problem.
Most do not like guessing, me included.
I do understand that you may have code not willing to show for any reason. But on the other hand how can one help if has no clue?
i have a suspicion about what the problem is but I'm not willing to waste time testing random
hypotheticals just for the chance to learn later that that's not actually your problem.
why don't you post the code you have tried, in fact rather than posting the complete project
aim to post the simplest compliable program that shows the problem. code snippets generally don't
cut it, we need to see the config settings, osc speed, var declarations, port settings, chip type etc....
dt_ints18 for k80 series works perfectly for both high and low priority interrupts for me
[note even the chip type is guesswork]
my stock for the stone soup
A number of interrupts for the K80 are different than what's in dt_ints-18.bas, so while it might compile it won't work properly without some adjustments.
As others have said, without seeing the OP's version it's hard to make recommendations.
Well after hours of searching I decided to look at the file with a hex editor. I found a non-printing character appended to the name of one of the interrupt routines. When I edited the character out, all compiled with no errors. I want to thank everyone for their help with this. I don't know where the character came from, but Henrik pointed this out once before on a different problem which is why I decided to look at this again. Tumbleweed, I did modify the interrupts to work with the K80 and have used this before with another program which is why this left me so confused. Ioannis, thanks for your patience with this. I consider this closed now if only I could find what is sticking random values into the ASCII.
Paul
Even a simple text editor could do that damage to the file and have such characters stored in them.
That is why posting the whole file helps us to help you.
Anyway, glad you got it working as you expected.
what chr did you find ?
every non-printing character i have tried caused a
WARNING Line 43: Bad token " ".
error
